The critical part of the concept is
spread anchors offset the need of heavy airborne compressive elements (masts, battens, spars, spreaders, booms…)
These compressed parts are used to stretch out working material into a tight efficient controllable shape.
Spreading anchors can replace the need for these components.
What the loop might look like. This would rotate along the longitudinal axis which means the kites are flying crosswind. And yes, there are better and simpler concepts out there.
Intriguing, though have a hard time trying to figure you what you are getting at? I see what look to be a deflector? With what seams to be an aerofoil?
Is that correct?
