Most kite line systems require some form of winching either for control or retraction.
Chain systems can use lighter handling gear with better grip at the expense of speed.
https://www.linkedin.com/posts/ortiz-fischer-y-cía-s-a_ortizfischer-elevesusexpectativas-greenpin-activity-6651567030547865600-DXQd
Tycan is a dyneema chain
Could be very useful for field lines, network lines, back lines… Lines which do not have fly fast with low drag.
Assuming a fast reciprocal line pumping isn’t going to use this.
I wonder how you’d make the chain. I imagine a jig that you’d use to tie two lines together. And then I wonder how you’d design the sprocket. You’d use bigger spacings between the teeth? And then I’d wonder about the durability of the chain. Does a sprocket result in more or less wear than winding the line around a pulley a few more times?
You can also imagine a hybrid dyneema/rigid material chain.
