"Tether Discretisation in Airborne Wind Energy Systems: Convergence and Computational Cost"
Nguyen, D.H.; Oland, E. Tether Discretisation in Airborne Wind Energy Systems: Convergence and Computational Cost. Aerospace 2026, 13, 943. https://doi.org/10.3390/aerospace13100943
An excerpt from the Abstract is shown below.
In time-marching simulation of airborne wind energy systems (AWESs), the tether is usually discretised into a series of lumped masses (i.e., nodes) connected by spring and damper elements. There is no consensus on the appropriate number of nodes for AWES applications, although it is known that using more nodes than necessary is computationally costly.
An excerpt from 1. Introduction is shown below.
From a flight dynamics perspective, AWES are characterised by the presence of the tether, which partially constrains the dynamics and adds considerable drag. An overview of different tether modelling methods can be found in Section 2 of [6]. In most AWES studies, the tether is usually modelled as either a rigid rod or a series of straight and elastic segments, each bounded by a pair of lumped masses connected by spring and damper elements. The rigid rod approach is common among both early studies and a few advanced simulation-based analyses due to its simplicity. Simulation results can be considered accurate if the tether tension remains high, thereby minimising tether bending, and the variation in aerodynamic force along the tether length is negligible. In practice, AWES can operate at altitudes exceeding 500 m, resulting in varying wind speed, local flow angle, and air density along the tether length and hence different aerodynamic forces. The straight-line assumption is no longer valid in such cases, thereby requiring a multi-segment modelling method.
2. Simulation Environment
This study uses a six-degree-of-freedom simulator of Kitemill’s KM1 prototype—a 20 kW groundgen system driven by a rigid-wing unmanned aerial vehicle, shown in Figure 3. The aerial vehicle weighs 57 kg and features a high aspect ratio wing, measuring 7.42 m in wingspan and 0.431 m in mean aerodynamic chord. Traditional trailing-edge control surfaces (aileron, elevator, and rudder) are used for flight control, in addition to flaps for increased lift during power production. Aerodynamic data of the KM1 airframe were obtained from computational fluid dynamics and saved as nonlinear polynomials, which are provided in Section 1 of [28].
3. Trim Analysis
During circular reel-out, gravity acts as an external periodic disturbance that destroys equilibria [25,30]. The issue is illustrated in Figure 4. Consider the circular trajectory depicted by the dashed lines, which has a radius of 60 m and is flown in a uniform horizontal wind field of strength 13 m/s. Since the circle is not normal to the wind direction or gravity, out-of-plane wind and gravitational force become two periodic disturbances that change direction relative to the kite’s body at different points on the circle. It has been shown that cyclic control inputs are required to maintain circular flights in these instances [25,30], and the resulting trajectory is a limit cycle. In the example in Figure 4, we use the flight controller in [31] to track 5° angle of attack and 0° sideslip while keeping the kite in orbit with a 60 m radius. The resulting closed-loop response is shown in Figure 5, where the periodic nature of the dynamics can be seen.
Reference 31:
Nguyen, D.H.; Porta Ko, A.; Tveide, T.; Lowenberg, M.H.; Oland, E. Controlling rigid-wing airborne wind energy systems during circular flight without exact path following. Wind Energy Sci. 2026, 11, 2987–3013.
Duc H. Nguyen, Agustí Porta Ko, Tallak Tveide, Mark H. Lowenberg, and Espen Oland
