Here is a revised history of airborne wind energy (AWE) with sources for the statements. Some early history is less well-documented, so some claims are more speculative or based on conference / journal‐review sources.
History of Airborne Wind Energy (with Sources)
Early Concepts and Theory (pre‑2000)
- The idea of using tethered wings or kites to harness wind energy at altitude has roots in early experiments and theoretical proposals. One of the foundational theoretical works is “Crosswind Kite Power” by Miles L. Loyd (1980), which analysed how a kite or tethered wing flying transverse to the wind could generate power (via tether tension or onboard turbines). (ADS)
- Studies of high‐altitude wind energy (beyond typical tower heights) emerged in later decades. E.g. Alexander Bolonkin’s 2004 paper “Utilization of Wind Energy at High Altitude” proposed large free‑flying air rotors at high altitude (1‑14 km) transmitting power via tethers. (arXiv)
- The concept of crosswind operation, where the kite moves perpendicular (or roughly so) to wind direction in loops or figure‑8s to increase apparent airspeed and thereby power, is central. Loyd’s theory quantifies how lift vs drag ratios, wing area, wind speed etc. determine potential power from such systems. (Wikipedia)
- TU Delft professor (astronaut) Wubbo Ockels proposed the “Laddermill” concept (a loop of kites or tethered wings) around early 2000s; this became an inspirational idea in Europe and among early AWE researchers and startups. (Wikipedia)
Rise of Prototypes and Early Startups (2000–2010)
- Makani Power was founded in 2006 by Saul Griffith, Don Montague, and Corwin Hardham. Its goal was to develop tethered aircraft (kites) that generate electricity. (Wikipedia)
- Makani got early funding via Google.org’s RE<C initiative, and later became part of Google X (Alphabet). (Wikipedia)
- Another important early company is Ampyx Power (Netherlands), founded in 2008, which grew out of research at Delft University of Technology. Ampyx initially worked with flexible membrane kites, and then moved to rigid wing designs. (Wikipedia)
- During this period, early prototypes were built: for example, Ampyx’s AP0‑AP2 series (2009‑2013) demonstrated feasibility, including autonomous flights. (Wikipedia)
- Also, SkySails (Germany) developed AWE prototypes (e.g. pump‑mode kites) during this period; for instance, a 55 kW prototype. (ResearchGate)
Growth, Scaling, and Challenges (2010‑2020)
- Makani developed larger scale prototypes. One important model was the M600 — a 600 kW energy kite with about 28‑meter wingspan. It was tested offshore / in more realistic conditions. (Wikipedia)
- In 2018‑2019, Makani tested offshore energy kite systems (e.g. off Big Island Hawaii, etc.), and also did work with Shell to explore commercial possibilities. (Wind Power Monthly)
- Ampyx Power likewise attempted scaling. They designed the AP3 prototype and had plans, and did work to validate aerodynamic tools, consider offshore deployment. (Wikipedia)
- Kitepower (Netherlands) is another more recent startup (mid‑2010s) focusing on membrane kites for power generation, often using figure‑8 flight patterns. (IO)
- Research advances in control systems, modeling of pumping kite cycles, and the dynamics of tethered aircraft have improved. e.g. the paper “Quasi‑Steady Model of a Pumping Kite Power System” (2017) presents a model validated by experimental measurements for a 20 kW system with tether up to ~720 m. (arXiv)
Setbacks, Closures, and Open Sourcing (2020‑present)
- In February 2020, Alphabet (parent of Google) officially shut down Makani. Makani acknowledged that despite technical progress, commercialization was more difficult and riskier than hoped. (Wikipedia)
- When Makani shut down, it made much of its technology, patents, flight logs, software, etc., open source (or in a “non‑assertion pledge”) to allow others to build upon it without legal risk. (IEEE Spectrum)
- Ampyx Power declared bankruptcy in 2022 after failing to secure sufficient investment to continue. (Wikipedia)
- The sector continues to iterate, with smaller players or startups carrying forward parts of the vision, focusing on robustness, material durability, regulatory issues, launching/landing, reliability, etc. (engineering.org.cn)
Key Technical / Conceptual Milestones
- Loyd’s 1980 paper Crosswind Kite Power introduced basic quantitative analyses: potential power output, influence of wing lift/drag ratio, tether drag, etc. This work is foundational. (ADS)
- Development of pump‑mode kite systems (traction systems) where the kite pulls on the tether to turn a ground generator, then is reeled in, etc. SkySails and others have experimented with those modes. (ResearchGate)
- Autonomous flight control of tethered aircraft / kites has been a key challenge. For example, the 2016 paper Autonomous Take‑Off and Flight of a Tethered Aircraft for AWE demonstrates fully autonomous take‑off, flights in figure‑8 patterns, and control of tether reeling. (arXiv)
If you like, I can assemble a fully referenced timeline (with dates, names, sources) you could embed in a paper or presentation.
