Hi. I have been working on this for a long time today I was able to finish it and clean it up a lot with the help of AI. I believe this is an important building block for the understanding of AWE. Enjoy!
Edit: I added a better closed form approximation of the drag for TRPT bringin the error down to less than 1-2% for where we are interested, and updated the link
Does tether sag cause a change in the angle attack of the kite? Is this a significant factor? Since the tether is connected to the bridling, then pulling the bridal at a slight angle because of sag will cause the angle of attack to change.
The formula: the tangential force balance gives the tether trailing the kite in the pitch plane by δ = asin(D_t/T_k). That is about ρv²C_D·d·l/(8T_k). The belly tilts the tether in roll, not pitch. The model has no gravity. For gravity the agent estimated the end slope as μ·g⊥·l/(2T_k), swinging between pitch and roll once per loop.
Depends on the moment arm of the tether attachment. For anything like kitemill that chabge in tether angle (1-10 deg) probably very minor impact. For a bridled kite much more impact.
I talked about this at an earlier AWEC, the change in apparent airflow over the loop along with moment of inertia of the kite would be the bigger impact IMHO. The dynamics of AWE flight is underappreciated in my opinion.
