Capex of an inexpensive flexible wing like NPW
The Breakdown of Initial Wind Turbine Costs
  • $2.6 – $4 million per average-sized commercial wind turbine
    • Typical cost is $1.3 million per megawatt (MW) of electricity-producing capacity
    • Most commercial wind turbines have a capacity of 2-3 MW, but offshore turbines can be as large as 16-18 MW
    • Cost increases as turbine size increases, though there are benefits to using fewer, larger turbines – complexity and construction of the overall farm site is greatly reduced with fewer and larger turbines.
Wind Turbine Maintenance Costs
Once built, maintenance is an ongoing expense.
  • 1-2 cents per kilowatt-hour produced, or
  • $42,000 – $48,000 per year
See also (in French language):
En France, pour installer un mégawatt d’éolien terrestre, l’investissement initial : le CAPEX, se situe entre 1 et 1,7 millions d’Euros. Tout dépend en effet de la hauteur des pâles de l’éolienne. Concernant la maintenance, le coût s’élève à 40 000€ par mégawatt par an.
Translation:
In France, to install a megawatt of onshore wind power, the initial investment: CAPEX, is between 1 and 1.7 million Euros. It all depends on the height of the blades of the wind turbine. Concerning maintenance, the cost amounts to €40,000 per megawatt per year.
Despite the unknowns of maintaining a wind turbine, we can think that this cost could be approximately similar to the cost of purchasing NPW kites per year and over 20 years (lifespan of a wind turbine) if a real industry is launched, also including the recycling of kites wherever possible.
That is, over 20 years, a total of €2,500,000 for a 1 MW wind turbine.
The price of our NPW would therefore be lower, assuming their lifespan is 1 year, which we do not know, knowing that we must take into account the reeling cycles which are certainly very tiring for the material, and a permanent use.
Now for AWES using NPW (or other kites), it is appropriate to add the cost of other components and the financial costs which are included in the cost of the wind turbines: generator and all the mechanics, ground station, possible electricity smoothing, reduction of secondary uses on the operating area, security measures, insurance, and so on.
It will be necessary to see the threshold of the AWE benefit when the exploitation of higher and more powerful altitude winds (possibly including the Low Level Jets (LLJs)), the saving in material (if we except the regular replacement of the kites) compensate for a lower efficiency of kites compared to wind turbine rotors, and the disadvantages linked to safety and high control requirements.
4 posts were merged into an existing topic: Slow Chat III
Such a low cost would perhaps be possible for a massive and standardized production.
Adding maintenance costs as mentioned above.
Operations & Maintenance $42,000 to $48,000 per year
This would be the cost of a 4500 m² NPW producing maybe 1 MW with a wind of 10 m/s, and taking into account the division by 2 because of reel-in phase in yo-yo mode.
Don’t forget the prices and costs of the ground station. That said, we would be close to acceptable or even competitive global costs by using NPW kites with higher long-lasting fabrics in difficult conditions when they become available.
