Climatic Impacts of Wind Power
An extract: “Increased GHG concentrations reduce radiative heat losses to space, trapping more heat in the atmosphere and causing warmer surface temperatures.Wind power does not add more heat to the atmosphere—wind turbines redistribute heat by mixing and alter large-scale flows both which can change climate.”
I guess that the impacts would be lesser with AWES as the concentration can be reduced, but this should be studied. In some way the maximization of the space is valid but only to a certain extent.
