All those ânews sitesâ regurgitatingâŠ
I still want to publish the definitive awes mainstream article free for anyone to copy to at least get them to have fewer things wrong.
Hi âwing-swept and isnât a swept-wing interestingâ Rod: Thatâs a swept-wing craft, (the shape is called a âchevronâ) with canard and winglets, not a delta wing.
A delta wing is shaped like, well, a delta (triangle).
Itâs funny how often we see âdoesnât need a towerâ.
I guess regular wind turbine people would say "doesnât need a special truck with a big powered arm to spin it around and fling it into the air, nor a tether to wear out, nor a reel with a gearbox, nor does it suffer from an intermittent power cycle, nor does it require a software pilot, per seâŠ
Also funny in the video âspins a turbineâ - people always want to call a generator a âturbineâ. I had one guy who kept insisting that my generators are the actual turbine. I had to explain, no the generator is the generator - the turbine is that thing that spins it.
a machine for producing continuous power in which a wheel or rotor, typically fitted with vanes, is made to revolve by a fast-moving flow of water, steam, gas, air, or other fluid.
Origin
mid 19th century: from French, from Latin turbo , turbin- âspinning top, whirlâ.
