Well It’s time to find out what the sensible end of the world makes of whacky Kite Turbine folks again…
I’ve entered
I’ve entered
Yeah, I think I’ve underestimated the R&D budget to date gone into Single Line AWES in that slide.
The how to make a Kite Turbine Write up has now been very much extended
please don’t consider making a Kite Turbine >1kW by following these guides… That would be too dodgy
Everything on that report is CC-BY-SA-4.0
Does the lift kite controller work and do you use it?
This is all description of the Old prototypes
Just Like it was here
Kite Turbines <1kW
Are now certified as open source hardware by the Open Source Hardware Association
UID is:
UK000038
Get building
Thank you @oshwassociation
