KiteGen vs Rotating Reel carousels
It is a comparative study. There are significant similarities of which the ground rotor diameter compared to the altitude of the kites (KG carousel) or the flying rotor (Rotating Reel). Values are respectively indicated on the page 14 (KG) and on the page 33 (RR) figure 22.18 on the layer in dark blue when the two rotors are close each other:
http://www.kitegen.com/pdf/dossierkitegenen.pdf
Resulting the common barrier is the large diameter of the ground rotor. But the advantages could overcome this.
Let us try to see the differences between the two carousels.
  • KiteGen implements numerous kites acting indirectly the ground rotor by making figure-eight. Resulting a larger torque and a slower ground ring speed.
  • Rotating Reel system implements the single flying rotor acting directly the ground rotor. Resulting a lesser torque and a higher ground ring speed.
Advantage for KG carousel: available kites.
Advantage for RR: more simple control.
High speed ground ring sounds better to me, as an electric generator works better at high \omega. Thus smaller gearboxes, less torque and friction
Relevant remark. It is thanks to the direct transmission between the flying and the ground rotors instead of several figure-eight for one revolution. Another advantage is an easier management as only one swept disk is considered instead of several moving areas of each kite flying their figure-eight with higher collision risk.
The Carousel concept in principle includes the rotating reeling mode if its kites are on reels, and those reeling motors work also as generators (motor-gens). Under conservation-of-energy principle, it does not matter critically where available energy is tapped, but under utility-scale generation economy-of-scale, a single generator tends to prevail.
Massimo (and NTS) ended up with a circular-track carousel concept, that also would in principle have a rotating-reel mode if there are reels on the cars. Again, its energetically comparable to tap either wheels or reels.
The overarching question is whether the upwind-downwind phases of an AWES circle track are necessary deviations from crosswind motion, for lack of any better architecture. If there are better architectures, this analytic contest between two similar not-so-good designs is moot.
A carousel prototype should be tested in both modes, and against all comers.
I think giant VAWT carousels (see below) can also be a basis for AWE carousels and their building is identical, the rigid sails being replaced with kites. So building a carousel for VAWT could be the same as for kites. That can be a fruitful start for mega-realization plan.
