Been looking into methods for broadcasting kite turbine rotor data
And of course there’s weight & longevity implications in batteries I’d rather avoid
Don’t want a drag based onboard turbine nor counter rotary drogue (although maybe)
anyway there’s probably enough energy from the movement itself because the power needs of a sensing and broadcast circuit are tiny…
(Note not looking for enough power for blade/wing actuator circuits)
Found these gizmos
https://xidasiot.com/power/ehm
https://xidasiot.com/power/veg
Depending where it is on a rotor … The power sourcing part may not be able to handle some of the g forces and I might have to artificially induce vibration with a ribbon reed or something…
Hmmm
any thoughts?
