I’m struggling to find a simple chart which shows turbine Life Cycle Analysis with regard to scale.
A simple graph of gCO2/kWh vs Turbine Rated Power
Does anyone know where to get one?
Energy return on energy invested ERORI used to be a big justification for AWES a decade ago.
And there were charts showing how …
As a normal wind turbine scales the mass becomes stupidly heavy.
Impossible to find
Any advice where I can get one please?
Page 532: “The development originated as an Advanced Concept Technology Demonstrator
research program from Natick Soldier Systems, whereby iteratively heavier
weight requirements were levied (0.25 ton, 1 ton, 2.25 tons, 4.5 tons, 13.5 tons, and
finally 19 tons). The wing sizes were 36 m2, 102 m2, 250 m2, 350 m2, 900 m2,
and 1,040 m2, respectively.”
Roddy: From what I remember, turbine mass scaled at somewhat less than the expected cubic function of diameter. I believe one possible reason could have something to do with the fact that as turbine size increases, wind speeds remain ~about~ the same, although I can’t say for sure if that is a true factor.
Another angle is, there are many weight-saving steps that can be taken, depending on how “worth the effort” they are. As turbines get larger, it is more “worth it” to take these weight reduction steps.
Yes tech advances are part of what I meant by “weight-saving steps”.
Better and faster pitch control and the ability to vary pitch of each blade independently throughout the rotation can reduce excessive loading on blades, hub, and entire drivetrain for example. Then they can use less material. Getting more picky and minimalist about how you design and lay up composites can reduce blade weight. Truncating the trailing edge of the widest part of the blade near the root is another material-saving step. They all add up.
