What sources do you like for historic and real-time weather and wind data?
The specific info I would be looking for in the sources would be how much of the time during the different months the wind is blowing at 10 m/s at ground level, and 100 meters up, in Europe.
And where I could get accurate real-time data, with a high resolution.
I don’t know where this topic should go.
PierreB
December 12, 2018, 10:23pm
2
Here is Cristina Archer’s publications: http://www.ceoe.udel.edu/our-people/profiles/carcher/my-publications . Cristina Archer is involved in airborne wind energy.
See also another view with Lee Miller’s and Alex Kleidon’s publications, from Max Planck Institute, on https://www.bgc-jena.mpg.de/index.php/BTM/LeeMiller .
Also https://earth.nullschool.net/#current/wind/surface/level/orthographic/loc=37.493,32.278 where one clicks in any part to know the wind speed, but without data about wind in altitude.
Tom
3
Resource Analysis- would put it in Industry and Market Analysis.
Tom
December 12, 2018, 10:28pm
4
A group involving Roland Schmehl will publish on the topic.
In the github docs for this there were good sources. Needs some digging to get to them.
See current wind, weather, ocean, and pollution conditions, as forecast by supercomputers, on an interactive animated map. Updated every three hours.
Thanks @PierreB , @Tom ! I’ll look through these.
tallakt
December 13, 2018, 6:36am
6
I believe windfinder has a means to see current wind at different altitudes
Rodread
December 16, 2018, 12:09am
7
Oh I like that site.
It says i’m full o crap… on the day of my recent test it’s windy like 12m/s (that was my upper gust I claimed)
Windy was forecasting similar (I think- ish)
Tom
December 16, 2018, 1:57pm
8
I don’t think the tool is that exact.
METAR Data parsing and processing is kPower’s conceptual approach to mesoscale AWES weather automation, as explored over many years on the Old Forum.
METAR is a format for reporting weather information. A METAR weather report is predominantly used by pilots in fulfillment of a part of a pre-flight weather briefing, and by meteorologists, who use aggregated METAR information to assist in weather forecasting.
Raw METAR is the most common format in the world for the transmission of observational weather data.[citation needed] It is highly standardized through the International Civil Aviation Organization (ICAO), which allows it to be understood ...
We use NREL website when preparing reports or doing research. For day-to-day current wind conditions, we use two apps that have been quite reliable. They are WindAlert and WindFinder Pro. We always cross check with the local weather forecast too. WindAlert will show up to 6 months historical data.
https://op.europa.eu/en/publication-detail/-/publication/a874f843-c137-11e8-9893-01aa75ed71a1/language-en
Page 70:
Stability
Recent measurements have shown that the wind speed on some sites does not increase significantly with height for large parts of the day and that wind speeds in low heights may already be optimal [163]. In the described cases, only during night time was the wind speed higher at higher altitude than at the height of conventional wind turbines [164]. For AWES to make optimal use of the available resource this means they need to be capable to work in different heights, depending on the available resource. When considering arrays of AWES, this may provide the opportunity to have different rows of AWES operate at different heights during daytime and night time, providing smoother use of the tether. However, the stability varies from region to region and site to site, requiring detailed information on the specific site to choose the right technology, site layout and operating strategy.
163 Gambier, Bastigkeit and Nippold, supra note 104 .
164 Ibid.
104 Bechtle, P., M. Schelbergen, R. Schmehl, U. Zillmann and S. Watson (2018), Airborne Wind Energy Resource Analysis,
Atmospheric and Oceanic Physics (submitted), [1808.07718] Airborne Wind Energy Resource Analysis
Gambier [23] and Gambier et al. [24] present a detailed modeling framework for AWE system designs and combine this with COSMO-EU and NCEP/DOE model data for 12 locations in and around Germany [23] as well as LIDAR measurements up to 1200 m at two locations in Germany [24]. The measurements reveal strong wind shear between 200 and 1000 m altitude during night time, while during the day the wind shear is small . Lunney et al. [25] present a techno-economic study of airborne wind energy harvesting in Ireland. The high-altitude wind resource was modeled on the basis of NCEP/DOE AMIP-II Reanalysis (R-2) data which provides an updated 6-hourly global analysis of atmospheric variables such as wind and temperature with143×73 grid points in the horizontal with spacing of 2.5◦ranging from the year 1979 to the present. Yip et al. [26] use MERRA-2 data to identify possible deployment areas for AWE in the Middle East, computing also the optimal height at which the systems would operate. Emeis[6] discusses AWE systems in his outlook chapter. Only very recently the Dutch Offshore WindAtlas (DOWA) has been published, consisting of 10 years of hourly data and covering the North Sea Region on a 2.5×2.5 km grid in 17 altitude levels up to 600 m. The data has been obtained by downscaling the ERA5 reanalysis using a regional numerical weather model together with additional satellite and aircraft measurements [27].
[24] Gambier A, Bastigkeit I, Nippold E. Projekt OnKites II : Untersuchung zu den Potentialen von Flugwindener-gieanlagen (FWEA) Phase II. Final Project Report; Fraunhofer Institute for Wind Energy and Energy SystemTechnology IWES; Bremerhaven, Germany; 2017. doi:10.2314/GBV:1009915452. Projekt OnKites II : Untersuchung zu den Potentialen von Flugwindenergieanlagen (FWEA) Phase II : Abschlussbericht (ausführliche Darstellung)
