Wind Fisher
Yes, and it corresponds to the equation (45) I quoted. As you noted: “In the frame of equilibrium motion theory, the power that can be generated with a tethered airfoil in crosswind conditions has been set by Loyd (1980) and refined in Argatov et al. (2009) to take into consideration the β losses:”. For a Magnus cylinder, it is the same, and the authors did not believe it necessary to “explain why it also should apply to rotating cylinders”.
Here it is the average elevation angle in relation to the entire crosswind eight-figure path which counts to determine the cosine, then the cosine squared if we only count the force of the wind, and finally the cosine cubed if we count the power of the wind.
You don’t give references for your statements.
I’m sure it is just a lack of understanding on my part, but I can’t trust unsourced claims to clear things up.
I haven’t read it yet, but in addition to the Argatov paper, this also seems like it could be relevant: Unified momentum model for rotor aerodynamics across operating regimes
Equation (45), as I mentioned several times.
For my second statement, the cosine is connected to the elevation angle. For example for 30 degrees, cosine is 0.8660. For power, wind speed is cubed, just like the cosine. See the equation (45) which also applies to Magnus cylinders in the concerned publication.
You need to understand how the equation was derived, where the cosine cubed comes from, to understand if it also applies to Magnus-effect based systems. For that the Argatov paper seems like a good start, the Magnus paper isn’t. A different question is if the equation, or model, matches reality, for either system, for that the paper in my last comment for example might be relevant.
No. Gupta’s publication is very well presented. It repeats Argatov’s conclusion, applying it to Magnus cylinders: both wind power and cosine are cubed for both airfoils and Magnus cylinders, as stated in the equation (45) and the text just before. It’s crystal clear.
The purpose of a reference is to say: it’s there I got the result or conclusion that I am using here, look at that if you want to know how the result came to be. So we look at the reference, in this case the Argatov paper.
The work to arrive at the equation was done in the Argotov paper, so we look at that to better understand the equation. The strength of the conclusion, the equation in this case, comes from the work that is described to come to the conclusion, math, arguments, or experiments. To look for the supporting math we go to the original paper, we don’t look at the later paper that only repeats the conclusion.
But to trust it, and to be able to conclude that it also should apply to Magnus-effect based systems, you would need to be able to follow along with the derivation. And again, a different question is how closely the model (equation) matches reality. That is probably going to be a different topic and off-topic here, but here are some references for that, in addition to the one in a previous comment:
I am following this a little. My initial thinking is that a magnus cylinder works like an airfoil wing, except you need to spend a little power to make it rotate. So anything Argatov wrote should still hold right? cosine cubed seems the most obvious correct answer.
So now I am wondering why this is being discussed, what did I miss?
I don’t think you missed anything. I fully agree with the content and quote of your comment.
If you see the need, we could open a topic on “cosine loss”, because we are going off topic. But is it really necessary?
From your reference:
The investigation performed by Urbán et al. (2019) shows that yaw misalignment of a turbine in the wake of another turbine can exhibit significant variations in the power–yaw loss exponent. In particular, α depends on the shape of the wake deficit profile, which evolves as it propagates downstream. The wake recovery rate is highly dependent on turbine spacing and ambient turbulence intensity.
“Power–yaw loss exponent” includes, next to cosine losses, “the wake recovery rate” which is “highly dependent on turbine spacing and ambient turbulence intensity”.
To come back to the topic, this would perhaps be a basis to calculate the loss within a farm of Wind Fisher Magnus balloons (or for any farm of any AWES), taking into account a misalignment of units if we think that this would reduce losses by increasing the “the wake recovery rate”.
We are therefore very far from the losses per cosine cubed as indicated by Argatov and taken up by Gupta for Magnus cylinders.
That’s not very rigorous is it? My question is here: Wind Fisher - #40 by Windy_Skies
Maybe you can look at the Argotov paper and understand where the cosine cubed in equation (69) comes from. I’m sure it’s correct but I wasn’t able to follow along, and with that can’t determine if it also should apply to Magnus effect-based systems.
Separately from that, the equation (model) does not match real-world data for conventional wind where there is also the cosine cubed rule, for example: WES - Analytical model for the power–yaw sensitivity of wind turbines operating in full wake
It’s not a stretch to imagine it also doesn’t hold for other systems.
The cubic cosine loss is based on a simplistic model. Any accurate
model would probably give slightly different results, I expect mostly more losses than cubic cosine losses.
It has been mentioned before, but cosine losses are not strictly losses in energy terms. I think when you are discussing wake losses we are taking about less usable wind energy available for downwind plants. Cosine losses are about producing less power relative to a theoretical downwind crosswind flight. Only theoretical because sustained production cant happen there without infinite turning speed of the kite [well, actually any AWE rotating in-place could achieve zero cosine losses, like Daisy/Pyramid].
So maybe this is a discussion that is a rabbit hole with very large depth, we will not be able to agree on this one, unless we get more rigid with definitions. And wake losses is a complex matter that probably can’t be advanced through forum discussion but rather real life observations and CFD simulations.
A post was merged into an existing topic: Slow Chat III
Why is the power output limited to 100% at 10 m/s? What do they do at higher wind velocities? (See report at 3-4mins)
I think you are referring to the curve at 3:15. The 100 kW power is supposed to be achieved with a rated wind speed of 10 m/s, and not increasing with higher wind. The same kind of curves can be found for traditional wind turbines, which generally achieve the rated power at about 10-15 m/s wind speed.
Significant progress in design and achievement for the MAG 15 of 15 m wingspan, towards the MAG 25, rated at 100 kW, 4 m in diameter X 25 m :
At 3:02: the balloon rotates at 40 rpm.
It is the MAG 15, so 15 m span.
Launching below:
description:
Hello Garrett @WindFisher,
Congratulations for your new MAG 15 (on the videos above).
I would have some questions please: has the design changed?
It seems that three secondary tethers hold the two ends and the connection between the two balloons, which allows for an increase in wingspan while using axial motors at both ends (?) to rotate the balloon or only one axial motor in the connection of the middle (?) (the ends being connected with an axial bar through said motor (?)), with the third secondary tether in the middle relieving the tension across the entire balloon (?), unlike the previous design where the motorized winches were installed in the ground station and acted peripheral ropes to rotate the balloon. Now the design looks like Omnidea design but with two connected balloons.
Perhaps the original design (in the rendering) was set aside because the fixed shells (with bearings?) around the balloon were slowing it down?
Are crosswind operations also being sidelined, in favor of vertical trajectory far from the winch for example?
To me, this effort seems to be more about emotion than reality. Everything they say is about “believing” rather than using it because it works well. Looks like too many people, too much spending, not enough reliable generation, I’d have to say you are looking at another “Makani”. All the theatrical music is like the dying gasp of a dinosaur, or maybe a mastdon sinking into The La Brea Tar Pits of wind energy - the drama of one more AWE idea being disproven, at a high cost. Very impressive attempt though, Pierre, it almost looks like your ideas and involvement could have been at play here. Luckily you have unlimited ideas, so there are always more! :slight_smile:
In French language:
An excerpt:
Notre techno va totalement écraser la concurrence avec une électricité à très bas coût [..]
Translation:
Our technology is going to totally crush the competition with very low-cost electricity […]
The race to make promises could well be the winning sector within the AWE field…
