"Wind Tunnel Load Measurements of a Leading-Edge Inflatable Kite Rigid Scale Model"
See also on the forum: Fast Aeroelastic Model of a Leading-Edge Inflatable Kite Uri Cayon, TU Delft and DTU - AWEC 2021 - AWESystems Forum.
TUDELFT_V3_KITE
Excerpt below.
New peer-reviewed publication out! :tada: Which explains WHY bridled soft-wing kites are roll-stable with anhedral, whereas aircraft need dihedral. :kite::airplane:
“Computational aerodynamics for leading-edge inflatable kite design”, now published in Wind Energy Science
:backhand_index_pointing_right: https://lnkd.in/gdS4fK_8
The short answer: an aircraft rotates about its centre of gravity, while a kite can be considered to rotate about its tow point. As the tow point generally lies far below the wing, an anhedral produces a restoring roll moment. Raise the point of rotation too far upwards (e.g. up to the centre of gravity), and the kite loses its roll stability with anhedral and instead -like a conventional aircraft- will require dihedral.
To get there, we built a fast and validated aerodynamic framework:
:small_blue_diamond: Vortex step method + 2D RANS airfoil polars: within 9% (lift) and 13% (drag) of wind-tunnel measurements in the operating range, with more consistent trends than 3D RANS
:small_blue_diamond: ML surrogate trained on >100,000 RANS simulations (R² > 0.98) for rapid design studies of any LEI airfoil
:small_blue_diamond: ~25 ms per evaluation, about a million times faster than 3D RANS
What the design studies show:
• Higher aspect ratio → better L/D, and a stronger restoring yaw moment
• More anhedral → lower L/D, but better turning
• Tow point further aft → higher trim angle and power potential, but the best-performing positions overlap with regions that are statically unstable in yaw (and, closer to the trailing edge, in pitch)
:right_arrow: Peak performance and stability margins don’t coincide, so kite design means trading one against the other.
This paper completes a Wind Energy Science series on the TU Delft V3 reference kite:
  1. Wind-tunnel load measurements → https://lnkd.in/gXNXz9u9
  2. PIV flow-field measurements → https://lnkd.in/gSEduN6U
  3. Fast, validated modelling: this paper
Poland, J. A. W., Masure, K. R. G., Cayon, O., and Schmehl, R.: Computational aerodynamics for leading-edge inflatable kite design, Wind Energ. Sci., 11, 4147–4178, https://doi.org/10.5194/wes-11-4147-2026, 2026.
