The sink rate of parachute rescues is low, being generally between 3 and 6 m/s, depending on whether they are soaring or not.
But at higher airflow speed, the drag (and also thrust) coefficient Cd (or Ct) is lower, for parasails (drag + lift = thrust) or parachutes (only drag):
The parasail is advantageous because it provides a lift component allowing it to fly at an elevation angle of about 30 or 35 degrees, which is a typical value for several AWES. As a result, the helium-inflated balloon is not required.
AWES parachute and wing-type systems feature a circular design that facilitates the installation of a depower line, possibly a crown line, near the power cable. This allows the kite to be retained by inverting it at its upper end in the event of a power cable break. It should be noted that depowering is performed via the control pod during reel-in phase, but this system may prove insufficient and present a risk of unexpected failure in the event of a break in the main tether during power reel-out phase.
The depower line from other kite systems could also be suitable, but can also be detrimental to the crosswind flight, by adding drag, weight, and complexity.
