Claim: Kites in a MAWES need to be able to: CLAMP onto the tether and LATCH onto the previous kite + a discussion on how to do this + a first mention of stackable kites + a concept for automatic launch of a soft kite train
In my idea the cams would sit between the nacelle and the spinner. It’s a two-part assembly. Fixed to the spinner, between the spinner and the nacelle, you would have concentric tubes (or arms) with holes at the bottom of each for the tethers to pass through. You would have a minimum of 2 of these concentric tubes if you use a single cam. Jutting out from the nacelle you would have the tubular cams. That is a part that can move in and out, moving in and out between the concentric tubes, depending on if you want to do cycling banking or not. It can also rotate if you need to compensate for different tensile shaft twists.
At first you could try not actuating the cams and just see if a fixed position of them works well enough.
The height of the tubes would be matched to the height difference of the cams. And say you use a single cam with a 30 centimeter height difference, you could vary the line length by a maximum of double that. You would need to extend the shaft coming from the nacelle then by 30 centimeters if you don’t allow the cam to move in and out, and by 60 centimeters if you do - unless you mount the two parts around the nacelle and spinner. So it might be better to use more cams instead, if that doesn’t make friction much worse
Still very keen to see some sort of model / sketching / toy version / patent … anything to get the physical orientation of components across more easily so that we can help you assess strengths weaknesses etc
For example:
a: threaded bolt, to raise and lower the mounting plate for the cams
b: tether
c: pulley riding on cam
d: cam
e: gear to turn mounting plate for threaded bolts, actuated by i.
f: mounting plate for cams, with threaded holes for a to actuate
g: mounting plate for threaded bolts, attached to shaft or nacelle with bearings
h: motor for bolts
i: motor, rotating cam plate depending on shaft twist
j: cover, fixed to spinner
k: nacelle, attached to shaft with bearings
l: shaft
m: spinner, fixed to shaft
n: not sketched and perhaps optional: grooves to constrain the pulley as it goes up and down
Note I make some mistakes in the sketch: You can see the pulley almost touching the top of the cover, but the mounting plate for the cams also almost touching the nacelle. So I’ve sketched the cam too tall here. In this position the pulley should be at the same height as the holes in the nacelle and cover for the tether, and there should be more distance between the nacelle and the spinner so the cam has some working distance, or alternatively you could make the plate f an annulus instead, going around the spinner. Also like I’ve sketched it here the bolts would interfere with the tethers (they should stop below the holes for the tethers anyway). Alternatives would be to replace the threaded holes with bearings that the bolts get fixed to, and the bolts going through the motors instead, or mounting the motors on the mounting plate, or annulus, for the cams instead and putting the threaded holes in the bottom, g, plate instead. Or just making the bolts shorter.
I’ve sketched a single cam. You can use more.
I’ve sketched the cam like a tube with a straight diagonal cut. More likely I think would be something like a sine wave. You can also imagine compound waves, one to do cycling banking, one to help with gravity slowdown, if that helps. Here the cam goes around the nacelle. It might also go between the nacelle and spinner.
As the spinner rotates, the tether is pushed up more and less by the cam throughout the rotation. As the mounting plate for the cam is lowered and raised, the tether is pushed up more and less by the cam. And as the mounting plate for the bolts is rotated, the cyclic banking occurs at different points of the rotation.
Brilliant Windy
Well done getting the sketch out, it seems to have opened up a whole host of possible configuration ideas.
2 questions…
What holds the nacelle or shaft from turning … Where does the torque come from so that energy can be imparted to the pulley carrier modulating the tether lengths?
Also
Will tether wear be significant?
Unless I am missing something… The nacelle is in line with the tensile shaft. The nacelle and cam are mostly fixed in place by the tower. The tethers go to arms, the arms are pulled on by the kites and cause the spinner to rotate. The rotation is retarded by the generator, which I haven’t drawn. So the tension required to go uphill comes from the turbine not freewheeling, or perhaps just the pull of the kites. If one kite can’t go up the cam, it is helped by the others going down the cam and rotating the spinner.
I don’t know. It seems like it would be and would be a drawback.You could think of ways to try to reduce it.
Edit: I didn’t like the previous sketch.
Inside the (green) gearbox there are two drums with cables that pull on the movable pulleys and so determine their position and with that the length of the tethers. You could actuate these drums with motors instead of with the cams to do testing.
Here I’ve drawn two cylindrical cams, one for each tether, 180 degrees out of phase with each other, see the next comment as to why. You could do circular cams instead, which might be easier to manufacture and take up less vertical space.
a1, a2: cams, fixed to nacelle, can be rotated. The only part drawn that does not rotate.
b: gearbox, fixed to shaft, can be lowered and heightened to increase or decrease steering, I think, if the gearbox and the steering pulleys are part of the same assembly.
c1, c2: acted on by the gearbox and lower and raise the steering pulleys
d1, d2: steering pulleys
e1, e2: drums
f1, f2: fixed pulleys
ga1, gb1, ga2, gb2: achieving a 90 degree angle in the tethers, arranged this way to reduce wind resistance
h: shaft
Not drawn: cam followers, covers, nacelle, arm, additional arms.
You could decide to do the majority of the steering from the ground so that other methods, a lifting kite or the kites steering themselves for example, have less to do.
I now use one (or multiple) cam(s) per tether, rotated 180 degrees from another. So that now tether travel of each tether is halved and tether wear is lessened and divided between the tethers. Control authority is presumably potentially raised. You can reduce tether wear presumably further by strengthening the parts that are frequently in contact with the pulleys and by varying the tether length so that different parts contact the pulleys.
Edit: I’m tending toward liking the idea from the previous comment better. The pulleys would have more distance to move along the arms for example.
Say you have 10 meter arms for example and you let the pulleys move 5 meters, you can vary each tether length by 2x5=10 meters, times 2 tethers for a 20 meter difference. At that point you could almost consider making a horizontal carousel.
Great to see the start in 3d development / design
It’s going to really help you get a feel for the physical properties / problems / relationships…
My top tip for everyone doing 3d design 3dconnexion spacemouse
using one saves sooo much time.
5m 10m arms … these sound like huge dimensions and masses to be flying
The longer the arms the better I think, at least for testing. Ideal would be if you could fly in a straight line and wouldn’t have to do any cyclic anything, second best would be to have as long arms as reasonable so you limit needed accelerations and so on and have more time to do things.
Say you’re going at 20 m/s, going in a straight line, or with arms that are 10 or 1 meter long:
\dfrac{circumference}{speed} => \dfrac{\infty}{20} = \infty \ seconds > \dfrac{2\pi *10}{20}= \pi \ seconds > \dfrac{2\pi *1}{20}= \dfrac{\pi}{10} \ seconds
Once you figure things out, you can decide if you want to make the arms shorter. You probably won’t as longer arms still should probably help with control, and power requirements, and torque transfer, and gearing / generator sizing (less need for rpm decreases from launch to flight as the flying radius increases).
This was done in SketchUp. I used to use that quite a lot. It does help. Now I try to do the same in SolidWorks or FreeCad, but you have to organize that correctly from the beginning or it gets messy, and I’m not so experienced yet, so it’s less conducive to doodling. I could go back to using SketchUp a bit more. Thanks for the tip on the mouse. I’ll look at some reviews.
I don’t see that. The velocity of the kites stays the same so the energy transferred should stay the same. One rotation does take longer, but there is more energy transferred in that one rotation also, equal to how much longer the rotation takes. You just do need longer arms, a taller tower, and a bigger gear ratio to the generator.
The work = force * distance in the two is the same, over the same time period. Only there are more friction losses from the gearbox with the bigger radius.
In return, a rotation takes longer, so your control software and your actuators have more time to do things. You could decrease the size of your actuators. You’d need less blade twist and both wingtips are flying at a more equal speed and generating more equal lift. You have more time to react to things, say to the shaft becoming over twisted, which takes longer, allowing you to risk operating closer to the limit. With the higher lambda you could also fly higher, in smoother and stronger winds, and further away from possible ground collisions.
Say you want to fly at a flying diameter of 9 vs 3 times kite wingspan, that gives you 3 times as much time to do anything, so you can use actuators that are 3 times smaller for example. Or take more time to do your calculations, and so on.
There are so many intertwining factors that’s why its so hard to explain. But I was thinking only about kite looping radius isolated, so the moment is not taken into account. Increase the looping radius and the airspeed of the kite should be expected to be the same, but rotary speed is reduced. And less rotary speed means less energy (of course unless you take into account some other effect that would compensate).
Larger kite looping radius only means that moment of the shaft could be increased. Nominally, the ground station would apply some braking moment to the shaft that is less than the moment where the shaft collapses. Increasing the moment limit does not mean the moment would actually increase also. The moment may not be limited only by the shaft, but also by what the right amount of moment would be to produce optimally. And for a well designed plant, the optimum moment would probably be somewhat less than the max possible…
Anyway, this is my mental model for this scenario.
That would be the greater force / moment. Rotary speed is reduced by 3, say, but force/moment is increased by 3 also, minus extra gearing losses.
Maybe what you’re getting at is that if the shaft was operating at maximum capacity with the kites flying in a smaller radius, and a higher shaft rotation speed, when you start increasing the flying radius, the shaft rotation speed will go down and with that the possible moment that the shaft can transmit – unless the greater moment transfer capability from the greater flying radius compensates that.
In my example the moment transfer capability of the shaft would need to multiplied by 3 also I think, so that it can still transmit 1/3 of that when it is going at 1/3 the speed – if my thinking on that is right. Is it?
With a greater difference between r0 (arm length) and r1 (kite flying radius) the less tether drag you would have.
I think we could add a bunch more maybes to this conversation.
Hey if you’re sitting at a university, with access to CFD software and a super-cluster…
Can you please run a range of configuration simulations of TRPT based AWES
Ask me any time for a set of parameterised models if you need them.
maybe 1
the same wings become more efficient at a larger diameter
maybe 2
We can’t launch a set of …
maybe 3
as long as parameter 23 and 61 are in the ratio 2:3 jackpot
Yes, you can call them variables and incorporate them in your (mental) model.
First is adding possible variables. What variables can you think of?
