[Core Green Energy Asset of the 15th FYP] Breaking the Fatal Bottleneck of "High Wind Speed Braking" – Transfer & Partnership Opportunities for Next-Gen Intelligent Micro-Wind Power Core Patents
:light_bulb: 致风电整机制造商、新能源开发商及绿能投资人:
:light_bulb: To Wind Turbine Manufacturers, Renewable Energy Developers, and Green Energy Investors:
在“十五五”绿能狂飙的时代,集中式光伏与大型水电已陷入内卷红海。真正的暴利与增量,藏在广袤的低风速区与分散式微风发电市场。
In the era of rapid green energy expansion under the 15th Five-Year Plan (FYP), utility-scale solar PV and large-scale hydropower have fallen into a fiercely competitive red ocean. The real high margins and incremental growth lie hidden in the vast low-wind-speed regions and the distributed micro-wind power market.
但当前市场上充斥着大量“伪微风发电”方案,导致项目频发安全事故、无法并网。本专利直击行业最核心的工程痛点,为您提供一张通往“十五五”分散式风电万亿市场的技术VIP门票。
However, the current market is flooded with numerous “pseudo-micro-wind” solutions, leading to frequent safety incidents and grid connection failures in projects. This patent directly addresses the industry’s most critical engineering pain point, providing you with a VIP technical ticket to the multi-trillion-dollar distributed wind power market of the 15th FYP.
:bar_chart: 宏观风口:为什么现在是拿下该专利的最佳时机?
:bar_chart: Macro Tailwinds: Why Is Now the Best Time to Acquire This Patent?
  1. 政策定调,分散式风电迎来“黄金五年”
  2. Policy Mandate: Distributed Wind Power Enters a “Golden Five Years”
    2026年7月,国家发改委、国家能源局联合印发《可再生能源发展“十五五”规划》,明确到2030年风光总装机超28亿千瓦。同时,国家能源局75号文《关于深入推进农村能源革命 开展村镇微能网建设试点工作的通知》正式引爆分散式风电“最后一公里”。“千乡万村驭风行动”全面提速,中小型、高安全性的微风发电设备需求呈井喷之势。
    In July 2026, the National Development and Reform Commission (NDRC) and the National Energy Administration (NEA) jointly issued the Renewable Energy Development 15th FYP, stipulating that total installed wind and solar capacity will exceed 2.8 billion kW by 2030. Simultaneously, NEA Document No. 75, Notice on Deepening Rural Energy Revolution and Launching Village/Town Microgrid Construction Pilots, officially ignited the “last mile” of distributed wind power. The “Wind Power for Thousands of Villages” initiative is accelerating across the board, triggering an explosive surge in demand for medium/small-scale, highly safe micro-wind power equipment.
  3. 核心痛点未解,市场呼唤“真技术”
  4. Core Pain Points Remain Unresolved: The Market Demands “Real Technology”
    目前市面上的中小型风机,大量采用落后的 “大风机带小发电机” 拼凑方案。该方案存在一个致命的工程缺陷:无法有效解决高风速下的风叶转速减速问题。 在突发阵风或台风边缘,极易引发“飞车”损毁事故,根本无法通过日益严苛的电网安全认证,更谈不上商业回报。
    Most small-to-medium wind turbines currently on the market rely heavily on outdated, cobbled-together solutions using “large rotors coupled with small generators.” This approach suffers from a fatal engineering flaw: the inability to effectively decelerate rotor speed under high wind conditions. During sudden gusts or typhoon peripheries, this easily triggers catastrophic “overspeed runaway” failures. Such equipment cannot pass increasingly stringent grid safety certifications, let alone deliver commercial returns.
    :hammer_and_wrench: 专利硬核揭秘:我们的技术凭什么值钱?
    :hammer_and_wrench: Patent Deep Dive: What Makes Our Technology Valuable?
    本专利彻底摒弃了落后的机械耦合限速方案,通过创新的气动/电磁复合制动与全功率解耦控制架构,完美解决了高风速减速难题,重新定义了微风发电的安全与效率边界。
    This patent completely abandons obsolete mechanical coupling speed-limitation schemes. Through an innovative aerodynamic/electromagnetic hybrid braking and full-power decoupled control architecture, it perfectly solves the high-wind-speed deceleration challenge, redefining the safety and efficiency boundaries of micro-wind power generation.
    :trophy: 三大核心技术壁垒(解决“卡脖子”痛点):
    :trophy: Three Core Technical Barriers (Solving Critical Bottlenecks):
    高风速平滑减速,彻底杜绝“飞车”风险
    Smooth Deceleration at High Wind Speeds, Completely Eliminating Overspeed Runaway Risks
    痛点终结: 突破传统机械刹车在高速下易磨损、易抱死断裂的瓶颈。本专利采用智能动态减速机制,在风速超过切出风速(如15m/s+)时,实现毫秒级响应、平滑卸载与气动/电磁复合制动,确保叶轮转速始终控制在安全阈值内。
    Pain Point Terminated: Breaks through the bottleneck of traditional mechanical brakes, which are prone to wear, seizure, and fracture at high speeds. This patent employs an intelligent dynamic deceleration mechanism that achieves millisecond-level response, smooth load shedding, and aerodynamic/electromagnetic hybrid braking when wind speed exceeds the cut-out threshold (e.g., >15 m/s), ensuring rotor speed remains strictly within safe limits.
    商业价值: 轻松通过国网严苛的并网安全测试,大幅降低设备保险费率与运维成本。
    Commercial Value: Easily passes State Grid’s stringent grid-connection safety tests, significantly reducing equipment insurance premiums and O&M costs.
    宽风速段高效捕能,LCOE(度电成本)直降20%
    High-Efficiency Energy Capture Across Wide Wind Speed Ranges, Slashing LCOE by 20%
    传统风机在低风速下“转不动”,高风速下“必须停”。本技术实现3m/s超低风速切入,并在中高风速段通过智能减速控制保持最优叶尖速比,年等效利用小时数提升15%-25%。
    Traditional turbines “can’t turn” at low wind speeds and “must stop” at high wind speeds. This technology enables ultra-low cut-in wind speeds of 3 m/s and maintains optimal tip-speed ratios through intelligent deceleration control in medium-to-high wind ranges, increasing annual equivalent utilization hours by 15%–25%.
    抗湍流与电网友好型设计
    Turbulence-Resistant and Grid-Friendly Design
    解耦了叶轮转速与电网频率,天然具备构网型(Grid-Forming)支撑能力,可为弱电网(如偏远乡村、海岛)提供电压和惯量支撑,完美契合“村镇微能网”建设需求。
    By decoupling rotor speed from grid frequency, the system inherently possesses Grid-Forming support capabilities, providing voltage and inertia support for weak grids (e.g., remote villages, islands), perfectly aligning with “Village/Town Microgrid” construction requirements.
    :money_bag: 商业变现路径:买下这个专利,你能在哪赚钱?
    :money_bag: Commercial Monetization Pathways: Where Can You Profit After Acquiring This Patent?
    掌握本专利,即可在以下“十五五”高溢价场景中降维打击竞争对手:
    Mastering this patent allows you to outclass competitors in the following high-premium scenarios under the 15th FYP:
    :sheaf_of_rice: “千乡万村驭风行动”整县打包: 针对乡村复杂地形和湍流环境,提供高安全、免维护的50kW-500kW级分散式风机方案,吃透村集体合作分红的长期红利。
    :sheaf_of_rice: County-Level Bundling for “Wind Power for Thousands of Villages”: Providing highly safe, maintenance-free 50kW–500kW distributed turbine solutions tailored for complex rural terrains and turbulent environments, fully capturing long-term dividends from village collective profit-sharing.
    :factory: 零碳园区与出口型企业微电网: 为面临“碳关税”压力的制造企业提供“风储直柔”一体化供电,设备溢价空间高达30%以上。
    :factory: Zero-Carbon Industrial Parks & Export-Oriented Enterprise Microgrids: Offering integrated “Wind-Storage-DC-Flexible” power supply for manufacturers facing “Carbon Border Tax” pressures, enabling equipment premium margins exceeding 30%.
    :desert_island: 海岛、偏远矿区、通信基站离网系统: 在抗台风要求极高的沿海及恶劣环境,本专利的“高风速可靠制动”是唯一的刚需卖点。
    :desert_island: Off-Grid Systems for Islands, Remote Mines, & Telecom Base Stations: In coastal and harsh environments with extreme typhoon-resistance requirements, this patent’s “reliable high-wind-speed braking” is the sole must-have selling point.
    :globe_showing_europe_africa: 海外新兴市场(东南亚/非洲)技术出海: 向缺乏核心控制技术的海外EPC商或整机厂进行专利授权,赚取高额技术许可费。
    :globe_showing_europe_africa: Technology Export to Emerging Overseas Markets (SE Asia/Africa): Licensing patents to overseas EPC contractors or OEMs lacking core control technologies to earn substantial licensing fees.
    :handshake: 合作模式与专利价值
    :handshake: Partnership Models & Patent Valuation
    本专利已获国家知识产权局授权(注:此处可填入专利号/类别),权利要求保护范围清晰,具备极强的技术排他性与商业化成熟度。
    This patent has been granted by the China National Intellectual Property Administration (CNIPA) (Note: Insert Patent No./Category here). It features clearly defined claim scopes, strong technological exclusivity, and high commercial maturity.
    我们寻求以下合作方式(真心想赚钱者来谈):
    We seek the following partnership models (Serious profit-driven investors only):
    专利所有权整体转让: 适合寻求技术转型、急需补齐“低风速/高安全”产品线短板的中小型风电整机制造商。(一口价或评估后议价)
    Full Transfer of Patent Ownership: Ideal for SME wind turbine manufacturers seeking technological transformation and urgently needing to fill gaps in their “low-wind/high-safety” product lines. (Fixed price or negotiable post-evaluation)
    独家/排他性技术许可: 适合特定区域(如东南沿海、海外市场)的新能源开发龙头,按区域或装机量收取License费用。
    Exclusive/Sole Technology Licensing: Suited for leading renewable energy developers in specific regions (e.g., SE China coast, overseas markets), with license fees based on territory or installed capacity.
    技术入股/联合开发: 针对有资金、有地方资源但缺核心技术的投资团队,我们可以专利作价入股,共同成立高端微风发电装备合资公司,共享“十五五”项目收益。
    Technology Equity/Joint Development: For investment teams with capital and local resources but lacking core technology. We can contribute the patent as equity to co-establish a JV for high-end micro-wind equipment, sharing project revenues under the 15th FYP.
    :warning: 最后的忠告
    :warning: Final Advisory
    在绿能行业,“概念”不值钱,“能解决致命工程缺陷的底层专利”才值钱。
    In the green energy sector, “concepts” are worthless; only “underlying patents that solve fatal engineering flaws” hold real value.
    当别人还在用“大带小”的拼装货去乡村市场忽悠补贴、面临飞车赔偿风险时,掌握本专利的你,已经拿到了并网通行证和高端市场的定价权。
    While others are still peddling cobbled-together “large-rotor-small-generator” assemblies in rural markets to game subsidies—facing overspeed liability risks—you, armed with this patent, will already hold the grid-connection pass and pricing power in the premium market.
    风口不等人,技术壁垒一旦形成,赢家通吃。
    Opportunities wait for no one. Once technological barriers are established, the winner takes all.
A post was merged into an existing topic: Patented Micro-Wind Constant Voltage & Constant Power Generation Technology for Sale (China Authorized Patent)
