In figure-eight or circular path the kite uses only a small part of the frontal airspace wind. This topic is intended to study trajectories that optimize the space by sweeping the largest possible wind area. Below is a thought about U-turn with zero radius allowing using a larger kite for the same tether length.
Some other topics were about a specific path such like
or
The present topic is about all possible ways to achieve its purpose.
The solidity can be roughly deduced from the Power Harvesting Factor ζ.
Solidity = 1/(Power Harvesting Factor ζ x 27/16). Some examples:
ζ = 5.5 for a wind turbine, solidity = 1/9.28);
ζ = 8 for Makani, L/D ratio = 7.35 with tether, solidity = 1/13.5;
ζ = 30 for a rigid kite with L/D ratio = 14.2, solidity = 1/51.
ζ = 4 for a flexible kite with L/D ratio = 5.2, solidity = 1/6.75;
ζ = 2.37 for a flexible kite with L/D ratio = 4, solidity = 1/4;
So a flexible (possibly networked) huge kite of ζ = 2.37 and solidity = 1/4 would be a reasonable start. The flight window could be maximized for different sorts of single kites.
