I would add that said frame is also required to support several rotors. As the frame undergoes wind force on the rotors, its weight will be significant as the system scales.
Well done, Doug. I think that several rotors would also be difficult to use because they can come into contact with each other when the wind weakens and traction decreases. What about a single turbine, the rope-drive being within the side discs, each disc comprising a deep notch to receive said rope-drive?
5 posts were merged into an existing topic: Some talk about Dust Devils and Thermals
The âLaddermillâ never worked, even without dust-devil.
The only way to see if laddermill works is to build one and run it, which, to my knowledge, nobody ever has. Then if one try did not work, it would still not disprove the concept. Iâm sure some version could at least âworkâ, but how well, and for how long would be the question.
There has been some excellent recent testing by Hironori Fuji from TMIT
VFinal-kWäšď˝MW fin.pdf (500.6 KB)
Indeed it is a fine document.
I put in quotation marks the passages translated approximately from Japanese language.
The figure 2 represents a crosswind drone carrying a horizontal VAWT and with likely a rope-drive transmission. In the text: âBy doing so, a basic study was conducted to aim for MW-class power generationâ.
The figure 3 represents a horizontal VAWT suspended by a kite and also with likely a rope-drive transmission. In the text: âIt is a 0.5 kW class wind turbineâ; âSince this method is equipped with a wind turbine, It is capable of continuous power generation, small scale up to about 50 kWâ.
The translation of the comments of the figures 2 and 3 is roughly:
âFigure 2: Ground-mounted generator with wind turbine (TMIT)â;
âFigure 3: Field test of a straight wind turbine with a kite hanging tether
(Generator installed on the ground/with wind turbine)â.
In the text of the second page:
â(3) Wind turbine (ground generator installed) type (W-Ground-Gen: With Windmill Ground Generator) Good performance as shown in Figure 2. A straight-blade wind turbine is installed on the UAV, and a tether is used to power the ground generator.â
I call as a âhorizontal VAWTâ what is named as a âstraight wind turbineâ by the translation.
Can you give a translation of some of the relevant points for those of us that donât read Japanese?
Is there some new info since this: http://www013.upp.so-net.ne.jp/tmit/windpower/19Oct15AWEC3DTrajectory.pdf and does it talk about rope drives?
I admit to having renewed interest in the laddermill concept in light of some recent understanding in my part. I have to admit that my earlier comments dis not describe the full picture. Still not sure if Iâm a fan though.
Operating a cable drive system in conjunction with a turbine system enables us to convert a flygen system to groundgen. The main advantage of this system is reduction of weight in the turbine system (no generator) and reduction in weight and cost of the tether (no electrical conductors). Because the system is much lighter, we can operate at much higher altitudes and capitalize on the higher wind velocity and more consistent winds. Variations in crosswind action can also be used to limit the maximum power output of the system in case of high winds.
The easiest way to operate with crosswind action is to convert the lifter kite to a power kite and operate in crosswind mode by means of a kite control unit (KCU). When the kite moves across the wind window either in a âlazy eightâ or circular pattern, the turbine system will move back and forth and not tend to rotate about the tether axis. This rotation around the tether axis adversely affects the cable drive system. We can minimize this effect by attaching the kite tether to the center of gravity of the turbine system, and provide a swivel joint for a circular pattern. This method is essentially a Kitewinder system with a power kite. The cable drive has vertical pulleys (horizontal axis) with the high tension side on the top and low tension side below. The drive pulley (top pulley) is linked to the turbine system so that changes in the direction of the turbines will cause the same changes in direction of the drive pulley. The generator and driven pulley is floating and will naturally move from side to side to align with the top pulley (drive pulley). This is not true in the case where the turbines are an integral part of the kite (Makani). In this case the drive pulley rotates around the tether axis to match the lazy-eight or circular motion. With Kitewinder, the lower driven pulley is free floating and will move back and forth to match the top pulley and thus avoid the cable rubbing against the walls of the sheaves. Unfortunately, the drive pulley direction is directly related to the turbine direction, so when the turbine rotates to face the effective wind direction, the drive pulley will be skewed relative to the driven pulley. (Letâs call this the âcant angleâ). This cant angle is significant. For example, if the crosswind velocity is 4 times the wind velocity, then the required cant angle will be 76° on each side. Without appreciable cant angle, crosswind action will be ineffectual. This cant angle makes operation of the cable drive ineffectual because the two pulleys are completely out of alignment. To counteract this we must realign the drive by means of carefully designed idler pulleys. Omnidirectional idler pulleys might be suitable to redirect the cable. Unfortunately scaling up this floating generator system might be very difficult because the weight of the floating driven pulley plus generator. Automatic operation of this system is also problematic.
An alternative method is my concept of a horizontal cable drive where the drive and return cable are in the same horizontal plane. This system must include 2 sets of omnidirectional idler pulleys (See drawing). The driven pulley and generator are anchored to the ground and the idler pulleys can freely rotate around the base to align with the top driving pulley.
Can anyone think of other ways to develop crosswind cable drives? I firmly believe that a cable drive system with a controlled lifter/power kite is easier to launch, land and automate than a Makani style system which requires onboard generators, batteries and/or inertial devices.
Crosswind Horizontal Cable Drive.pdf (70.2 KB)
I would like to summarize my thoughts on what I consider the most viable autonomous AWE system which can be developed. The Kitewinder system is the closest thing to steady state operation, depending only on wind speed. There is no variation in power output due to yo-yo retraction or variable forces due to crosswind action. Kitewinder is also the lightest system because there are no generators aloft or conductive cables. The cable drive is also used as the tether. This enables us to operate at higher altitudes where winds are stronger and more consistent. I also believe that we should use the turbines only for power generation and not lift since angled turbines diminish power and more lift can be achieved by a larger lifter kite. There is an advantage to using multiple small turbines because of increased power to weight ratio and the higher turbine speed results in higher cable drive speeds and lighter cables. Multiple turbines require a frame to secure them and orient them to face the wind. It is advantageous to have multiple counterrotating trains to neutralize transverse torque and prevent the a whole system from rotating around the cable drive axis. Kitewinder has a floating generator which may not be suitable for permanent installations. For this reason I recommend a fixed vertical axis generator with a horizontal driven cable drive pulley. In this way we do not have to move the generator when the wind direction changes.
With regard to autonomous launch and land, I have proposed a fully restrained kite with diagonal stays at the four corners. The kite is fully spread out at all times and when landed it rests on an LTA tubular frame. The kite is lifted to an adequate launching height and the LTA tubular frame is retracted. Alternatively a regular frame is lifted by lever-arm, telescoping arms or scissor lifts etc. It also occurred to me that perhaps we can eliminate the cable wind-up function. If the cable drive/tether is fully extended at all times, then perhaps we can launch the kite by controlled unwinding of the four diagonal stays. Landing will be the reverse of this procedure. With this method we can continue to operate the turbines for most of the time that the kite is being launched and landed.
AUTONOMOUS.pdf (86.7 KB)
Since my original post I have come up with some additional ideas, but first I would like to comment on some of my original statements.
⢠The size of the lifter kite increases to the point where it is difficult and dangerous to launch and land.
If a power kite is used then the size of the kite can be much smaller though autonomous launch and land system is still a problem.
⢠A larger turbine will rotate at a much slower velocity requiring more gearing to operate the rope drive efficiently.
The diameter of the drive pulley of the rope drive can be made very large and this effectively increases the rope speed, causing lower rope tension, thinner ropes and more power transfer. The large drive pulley can also be used as a support for the turbine(s), Daisy or MAR3. (See attached)
⢠The system is not easily adaptable to incorporate multiple turbines.
Although a frame adds more weight to the system, it is necessary to support the turbines and pulleys. It also aids in orienting the system to face the wind. The frame can be aerodynamically designed to provide lift and to protect the turbines from damage during launch and land.
⢠The floating generator will become too heavy and an alternate support method will be required.
Although a vertical axis generator and driven pulley would be more convenient for adjusting to crosswind kite movements and changes in wind direction, a floating pulley/generator could be supported on a rotating turntable.
⢠Operating the lifter kite in figure-of-eight crosswind mode might cause the rope drive to rub against the walls of the pulleys causing wear and a reduction in rope drive efficiency.
If we operate the Kitewinder lifter kite in crosswind mode (eg. lazy eight) then the turbine(s) suspended below will follow the same pattern but will not rotate around the tether axis as the lifter or power kite does. The turbines will move from side to side with only a slight up and down movement (lazy eight). The paddle on the Kitewinder will cause the turbine(s) to âcantâ in the the effective wind direction. This cant angle can be as much as 60-70 deg. The present cable has drive and driven pulleys which are vertical and so the cant will cause the cable to rub on the walls of the drive pulley. If the drive pulley is horizontal, then this problem is avoided. In the attached sketch (excuse my lousy drawing) I have used two counterrotating turbines to neutralize torque. The cable drive is a serpentine rope which passes around the two drive wheels and is transferred to the ground by means of horizontal angled idler pulleys. The cant angle will wrap or unwrap the rope around the idler pulleys and not rub the walls of the pulleys.
Assuming each turbine will produce 200 watts at a wind velocity of 8 m/sec then we can expect power outputs of 3 - 10 KW at effective wind velocities of 2 - 3 times the 8 m/ sec respectively. This power output is intermittent, dropping to almost zero at the turnarounds. Kitewinderâs data using a moving vehicle shows that an equivalent turbine area would only generate 1.1 KW at 28 m/sec. Evidently the combination of cable drive losses and and turbine inefficiency limits the power output.
My latest embodiment of an autonomous Kitewinder system consists of the following:
- Dual or multiple turbines mounted in a fixed frame and lifted to a high altitude by means of a lifter kite. The turbine system is oriented to face the wind.
- The turbine system is connected to the ground by means of a cable drive. This cable drive does not have to be wound up when retracting the system, only the lifter kite has to be lowered while the cable drive remains fully extended.
- The lifter kite is equipped with four lines connected to the corners. The purpose of these lines is to retract the kite and land it on a fixed lifting platform when conditions are not suitable. Retraction can be fairly rapid because the force required to lower a kite is not working directly against the wind and so we are able to retract the kite at a rapid rate. For example if we retract the kite from a height of 1 kilometer at the rate of 12 m/s it will require 83 seconds to lower the kite.
- The four wind-up lines are directed to a single wind-up station through pulleys anchored to the ground.
The system is scalable up to the limit of the lifter kite size which is unknown. Larger turbines will rotate slower requiring more gear reduction in the cable drive.
If we assume that the average wind speed increases from 8 m/sec to 11 m/sec at 1 kilometer elevation, then the available power increases by a factor of 2.6. The Kitewinder design also orients the turbines to face the wind, which would increase the power by a factor of 1.3 compared to a Daisy or MAR3 system at 40 deg. tether angle. The overall increase in power would therefore be a factor of 3.4 compared to Daisy, MAR3 or Skyserpent.
I dont understand where the lifted fixed frame is in the drawing.
Also I dont understand why you would not prefer a single line attatched to the KCU rather than four lines at the corners
This is a drawing of the lifter kite only.
This is a single skin kite which will collapse if not restrained at the corners. The kite must remain spread out for the next launch.
