The Baler has it’s own motor, it is geared in such a way to maintain position especially with an external brake and motor power. The Baler, Orbital reel, and Depower all have hand crank inputs as an option to power the winch, which could be useful for sailing
The the Baler is under its own power and able to rotate without the clutch. The clutch serves to link the Orbital reel, Depower reel, and/or the Baler primarily for computational ease. Now the winch is able to split power between any of the motors providing redundancy in case of motor loss and/or heat management. The winch works in such a way that all of the motors can link together and share the same axle. This means for looping procedures, the winch uses minimal power and needs less computational control. Under manual control it is as easy as a fishing reel. This mode is also great for sailing where one might not want to manage all the lines while conducting maneuvers. One would primarily use the tether winch to steer the kite.
However, with an AWES we can use computational energy to produce an order of magnitude more electrical energy. In this mode we would not use the clutch. This is not a problem as only the Baler uses minimal power, All the other reels/motors employ regenerative braking.
We would monitor the current and RPMs to determine tension and distance.
The overall control scheme would be to maintain the proper relative differences between the tethers to maintain a predictable flight path. Ideally we want a predictable circular flight path. Once this is achieved we want to maintain those relative tether lengths and release line via regenerative braking to generate power.
Unfortunately I have not determined a mechanical solution to rotate the baler and perform loops automatically as knowing Kite RPM is necessary to know what rate to turn the associated reels/baler… I have really tried to think of ways to avoid telemetry and cameras and keep sensors all local. Beyond that, I couldn’t devise a strictly mechanical system to process visual information into data… This will most likely have to be done via camera and software.
If the position of the kite was known and you still wanted to do this mechanically, the winch would become more dense, and appear more like some kind of swiss clock than a piece of line management tool
