Network Kites and Daisy network kite rotors
There are 2 chief advantages to anchoring the backline (or holding to a ground circle)
The backline can be set tight, this holds the top of the turbine a set height so that the turbine is at a set elevation angle. Sweet. Until the wind changes. I used to use a running line back anchor to cope better with swings of direction… No need.
Next advantage… A huge safety one. The back anchor is strong enough to hold the lift kite for launch and recovery plus more. So assume stuff breaks, like 7 tethers once did, or say if you f up main anchoring at the ground station, stuff shouldn’t fly far past the back anchor.
Double sweet.
A few more advantages can be sewn onto a back line and anchor set
Please take a new portrait photo without blitz :slight_smile:
The teabag method can add mass (sand, water) to duplicate the functions of a fixed anchor, including killing the rig in the event of a main-axis failure. Its also possible to rig wheels or runners for variable teabag mobility, or work a back anchor along a traveler.
Its engineering trade-offs between fixed wind directions, like Trade Winds; and wildly fluctuating wind directions, like Horse Latitudes; and supervisory availability.
After so long arguing against systems which could have a dragging anchor. It will be surprising for some readers to see that argument in favour of a drag-able anchor.
KiteLab Group has long found draggable anchors a useful rigging method. In fact, most kite sports are draggable-anchor based. A suitably designed anchor-drag force absorbs gust surge, for both dragging human anchors, or to keep an AWES within working load limits.
Be careful to distinguish from unplanned catastrophic anchor dragging. That’s why water or sand ballast is recommended above for teabag use, that will not survive extended dragging. kPower makes anchor force arguments both ways, on specific engineering merits.
That’s not right.
You’re picking and choosing.
It’s somehow ok for @kitefreak to drag a high energy line wildly out of control but not ok for an engineering team to do it.
Anyone else other than @kitefreak see it as fine as @kitefreak does?
Untrue, its always wrong to create a hazard, including if kPower was ever “to drag a high energy line out of control”, not just Kitepower, which did drag such a line out of control.
If Kitepower had used either a teabag or fixed-anchor based kite-killer backline, they could have prevented runaway deep into Valkenburg.
Teabag
Well, … Let’s not get into semantics here… Needless to say… if urbandictionary.com has a translation of the word… It aint going to be nice. Did you know actual teabags are made using plastic… So so annoyed when I discovered that.
I presume you mean a sand anchor type arrangement… A gather-able bag with strapping sewn on…?
I use 1 ton gravel delivery bags for this when I fly big lifters on the beach.
I’ve considered the sinking of the same bags in a circle array on my croft. Seems good in principle.
A semi permeable sack with very strong straps, dug into the ground and back filled with the earth removed from the hole. However… I was helping a neighbour fill in pot holes on Tuesday. His 1 ton gravel bag had been sat outside for a year and been degraded by weeds & water.
I do still hold out hope for a tensile bag anchor circle system like this… But it needs to be deep in the ground and not able to flap about in the breeze on the end of a safety back-line.
Sorry for going off topic here, but in the interest of reducing worldwide plastic waste: Clipper has very nice organic tea and the teabags are just a paper bag without the string and label.
No one should be against traction-kiting’s inherent anchor-dragging dynamic. “Teabagging” is an established kitesurfing term, like this sample quote-
“In kitesurfing, they call this teabagging. A slip of the board means getting dragged in and out of the water, like a tea bag.” https://www.facebook.com/nochairlifts/videos/425092861432572/
KiteLab extended this “teabag” usage to apply to bag anchors that generally stay in place, but may move during gust surge or weathervaning. As long as the Daisy relies on a fixed-anchor backline, it can’t weathervane without manual intervention.
A bag anchor-kill trick is a slip-knot at the bag whose tail is secured by a stake. If the bag drags, the knot releases. All power tech has safe and dangerous cases, as a two-edged sword.
It seems my wife has been correct all along on the topic of network kites and daisy kite rotors…
She insists on loose tea leaves in a lenticular mesh strainer… Like Gaudi, she must have realised, the 3d drooping wire net catenary form, is the best fit analogue to the inverted lifting kite net form, and still torsionally rigid enough to keep the tea leaves in the water when we swirl the pot, thus mimicking the functionality of the Daisy Kite model at the same time. She’s genius
Phew at last, the forecast was below 10m/s and not too gusty
I got out and did a test of the new polygonal transmission.
6 lowest parts in the pic.
Worked ace!
There’s Sharavan explaining the system to our MSP Alasdair Allan.
The main ring peaked at 1025W then one, then another, main ring tube snapped behind the fuselage.
Redesign to polygonal coming to the fuselages. Among other changes.
Oh there’s no centre lines on the new transmission or main lift line through the turbine. cool.
Great looking rig, Rod.
Its about time Lewis came together to become a major AWES Testing Location, under your leadership. The economy needs a new foundation.
The sketched design is derived from the rotating reel system, here being only an angle gear with rope but without gear for reduction. Unfortunately this system works as a direct transmission, in such a way that the angular speed is the same for both rings. And the rings cannot be too small when a fast rope-drive action is wanted.
A bevel gear with reduction (like on the page below) would be required in such a way that the larger ring (taking the rotational speed from the rotating kite) transmits its motion to the smaller ring at the same linear velocity, so at different angular velocity. But such a system should be light enough. A system with only ropes would be nice if it is feasible.
Indeed keeping the two rings in the air does not facilitate the transmission of the torque despite the tension. And in addition that would require a heavy material due to the diameter of both rings.
I wonder if the 10 KW could be divided into a complete network of 6 or 7 units reproducing what already exists individually. What do you think about @Rodread?
The intention of the project is to test various modular kite turbine techno-economic propositions and
yes that includes their modular deployment
Pretty certain at this point the standard 10kW reference model will be a 3 rotor x 5 blade configuration
so We’ll start testing a single rotor 5 blade 3kW set and add more similar on top.
That’ll allow us to assess various aspects of performance, interaction reliability…
An illuminating description of the stability of networked lifter kites, compared to instability without a network:
More generally, one could consider “Rotary Kite Networks” as a mean to mitigate crosswind flight inefficiency, scalability and mess issues.
A point that unites concepts such as AlphAnemo, The Pyramid, Daisy, and maybe others, is the tether arrangement to connect the blades or the kites, allowing to stabilize the set and probably to improve the crosswind flight efficiency by a regular kite speed. Indeed Daisy is a beginning of proof of concept for tether arrangement with a good power coefficient of 0.15 to 0.2.
One can imagine a tether arrangement connecting a gigantic rotary network of kites harnessing high altitude winds, perhaps in yo-yo mode.
To explore
I am interested to know how you came up with this power coefficient number. What is the power coefficient of a kite winder system?
On https://forum.awesystems.info/t/daisy-progress-with-rigid-blades/121/80:
15.8% (AWES style), and 13.8% (wind power style), i.e. power coefficients (Cp) respectively of 0.158 and 0.138. I remember having seen other measures, but I don’t remember where, maybe in @Ollie 's publications.
Concerning Kiwee:
Swept area is approximately 1 m². 210 Watt at 10 m/s wind speed lead to a power coefficient (Cp) of 0.35 with air density of 1.2. Simple calculation: 210 / (1/2 x 1000 x 1.2).
