Would have thought they should have hit a soft spot with you given the similarities with ST. Alas…
Havent seen that 3D rendering of the ST before. Looks sweet!
Yeah thanks Tallak. There’s a lot most people don’t know about my work. For example I am the officially recognized inventor of the spar buoy floating offshore wind turbine foundation concept, and other related floating offshore wind design concepts:
Are you sure you didnt lift that off the kPower «group»? ![]()
From what I hear they invented that first… And I have the picture to prove it, dated 2009…
Anyways, hope you’ll accept Norwegian $ for your patent, not just US [as the article hints at]…
Hi Tallak: Sure I’ll accept Norwegian oil money! ![]()
Look to the lower right of the image you sent: Sept 16, 2021. Sorry, but I’ve lost faith in anything related to kPower… Just a guess here - maybe someone swiped the image from elsewhere and slapped their logo on it? Looks like it could use a bit more flotation! What is holding it up, to prevent it from sinking? Hmm, lamest spar-buoy image I’ve seen = maybe it IS original - but why would kPower show an image of anything that could possibly produce any power? Oh wait: “Optimized” - I guess that’s like “advanced” - a self-inflicted compliment before the fact?
My original disclosure is far older than the resulting patent.
kPower invented retroactive prior art. ![]()
Apart from all this, see also a patent filed in 2006, by Norwegian inventors:
And also an old (1921) patent about multiple rotors:
Hi Pierre:
As to the first reference, my priority date precedes theirs.
The second reference was acknowledged as prior art in my patents, with my inventive steps going beyond…
I think though that the kPower “group” is adding steel mass to the tower as an inventive step, and also has this heave damper to set it apart from a buoy that other people would possibly go for.
They are Copy-Cats. They’ve even got a rotating tower. Their renderings look like copies of mine:
www.selsam.com
Can you be more specific?
Hi Tallak: If you visit my website, link in previous message, you can see for yourself.
Besides the entire wind industry adopting my spar buoy floating base, this company is copying everything from the rotating shaft and possibly the base itself, to the same tilt angle, same 3 anchors, same weather and look, showing a similar number of turbines, with similar spacing, similar views including from underwater at various angles. Nobody was doing this before me. All roads lead to SuperTurbine™ and people are slowly migrating toward that reality from various directions.
I get the feeling that you have sketch out every possible wind turbine design. That’s also quite a feat ![]()
