Preprint: Towards a gigantic Magnus balloon with motorized belts
I wondered if it was possible to have a balloon inflated with nitrogen (inexpensive, common, and non-flammable), knowing that the weak aerostatic thrust would perhaps be sufficient to compensate for the mass of the envelope, and also ensure stability.
On this topic:
https://www.quora.com/Could-we-build-airships-again-using-nitrogen-Its-lighter-than-air-or-is-the-buoyancy-not-enough-because-its-78-air
Could we build airships again using nitrogen? It’s lighter than air, or is the buoyancy not enough because it’s 78% air?
Two representative answers:
Profile photo for Lucas Curtis
Lucas Curtis
Follow
Science teacher (2001–present)5y
The density of nitrogen at 20ºC and 1 atmosphere of pressure is 1.165 grams per liter.
The density of air at 20ºC and 1 atmosphere of pressure is 1.205 grams per liter.
While pure nitrogen is less dense than air, it’s not enough of a difference to allow a nitrogen-filled airship to lift any significant weight.
The Hindenburg held a whopping 200,000 cubic meters (200 million liters) of hydrogen gas. If you had a blimp of the same size, but filled with nitrogen instead of hydrogen, its internal mass would be 233 million grams (233 metric tons). Assuming the skin of the blimp is negligibly thin, it will displace 200 million liters of air, with a mass of 241 million grams (241 metric tons). So the buoyant force acting on this gas-filled bladder would be equivalent to the weight of 8 metric tons.
The Hindenburg’s average gross weight — that is, the weight of the ship without hydrogen — was 215 tons. Ergo, a Hindenburg-sized blimp, filled with nitrogen instead of hydrogen or helium, would be woefully inadequate to lift its own weight, let alone any passengers or cargo.
Yes, nitrogen is slightly lighter than air, all other things being equal. But for an airship, you need a gas that is much lighter than air. Nitrogen just won’t cut it.
Profile photo for Kim Aaron
Kim Aaron
Follow
Has PhD in fluid dynamics from Caltech
· 5y
No. The 78% you are quoting is NOT the ratio of nitrogen density to air density. It is the fraction of air that is nitrogen. The other 22% is mostly oxygen and a few other traces gases. The density ratio - the thing that matters for buoyancy - is more like 97%. Good luck taking advantage of that 3% difference. In principle, this could be made to float. But it’s a rather poor starting point.
For all balloons supposed to work in pumping mode (Wind Fisher, Omnidea, this one and others), the aerostatic thrust should be approximately neutral to facilitate the recovery reel-in phases, and also ensure stability.
There are no passengers, and possibly no aloft motors if the @WindFisher system was applied, just the envelope and the tethers.
Now let us try with several sizes, knowing the square law for the area, and the cube law for the volume leading to the aerostatic thrust, which is noted in kg to simplify, knowing that for 1 m³, it is about 0.035 kg. Below are some rough calculations for cylindrical balloons made of a film of 0.2 kg/m².
50 m span and 10 m in diameter.
Mass: about 350-400 kg.
Volume: 3925 m³.
Aerostatic thrust: 137 kg. It is not enough!
100 m span and 20 m diameter balloon.
Mass: 1400-1500 kg.
Volume: 31400 m³.
Aerostatic thrust: 1100 kg. Just a little more effort!
200 m span and 40 m diameter balloon.
Mass: 6000-6500 kg.
Volume: 251200 m³.
Aerostatic thrust: 8800 kg. We are a little above, but not if we count the tethers, and the discs around the balloon.
And for such dimensions it will not be possible to pressurize the gas contained in order to have a sufficiently rigid shape to avoid overconsumption for the rotation motors, unless the thickness and mass of the envelope film are increased, or/and some light rigid rods should be integrated.
So using nitrogen is therefore a possibility but not a probability. For giant balloons like this, it would perhaps be a better (or a worse) alternative to the heating wire which requires an electric cable from the ground station.
ChatGPT says
At ground level, air is composed primarily of nitrogen (N₂, ~78%) and oxygen (O₂, ~21%), with an average molar mass of about 29 g/mol.
Gases that are lighter than air will have a lower molar mass than this.
Here’s a list of lighter-than-air gases and their molar masses relative to air:
  1. Hydrogen (H₂)
    • Molar mass: 2.02 g/mol
    • Relative to air: ~1/14th the density of air
    • Notes: Hydrogen is the lightest gas and highly flammable.
  2. Helium (He)
    • Molar mass: 4.00 g/mol
    • Relative to air: ~1/7th the density of air
    • Notes: Helium is inert and non-flammable, making it ideal for balloons and airships.
  3. Ammonia (NH₃)
    • Molar mass: 17.03 g/mol
    • Relative to air: ~0.59 times the density of air
    • Notes: Ammonia is less dense than air but has a strong odor and is toxic.
  4. Methane (CH₄)
    • Molar mass: 16.04 g/mol
    • Relative to air: ~0.55 times the density of air
    • Notes: Methane is highly flammable and a major component of natural gas.
  5. Neon (Ne)
    • Molar mass: 20.18 g/mol
    • Relative to air: ~0.7 times the density of air
    • Notes: Neon is inert and used in neon signs.
  6. Acetylene (C₂H₂)
    • Molar mass: 26.04 g/mol
    • Relative to air: ~0.9 times the density of air
    • Notes: Acetylene is used as a fuel in welding and is highly flammable.
  7. Ethylene (C₂H₄)
    • Molar mass: 28.05 g/mol
    • Relative to air: ~0.97 times the density of air
    • Notes: Ethylene is close to the density of air but slightly lighter. It’s used in the production of plastics.
These gases are all less dense than air and will rise or disperse quickly in the atmosphere.
The suitability of these gases for applications (like balloons or airships) depends not only on their buoyancy but also on factors such as safety, reactivity,
And about leakage
When comparing gases in terms of leakage through a membrane, two primary factors come into play: the size (molecular weight) of the gas molecules and the membrane permeability to those molecules.
Key Factors:
  1. Molecular Size: Smaller, lighter gases will typically leak faster than heavier, larger ones because they can more easily pass through microscopic pores in the membrane. The lighter the gas, the higher its rate of diffusion.
  2. Membrane Permeability: Different membrane materials have varying levels of permeability to different gases. Some membranes may allow certain gases to pass through more easily due to their chemical structure or molecular interaction with the material.
Comparing Leakage of Gases:
  1. Hydrogen (H₂):
    • Molar mass: 2.02 g/mol (lightest)
    • Leakage rate: Extremely high due to its small molecular size. Hydrogen diffuses faster through membranes compared to any other gas on this list.
    • Applications: Hydrogen gas can quickly escape through small pores or imperfections in a membrane.
  2. Helium (He):
    • Leakage rate: Very high, but slightly slower than hydrogen. Helium atoms are very small and inert, making them highly prone to leakage.
    • Applications: Helium is often used to test for leaks in systems due to its tendency to escape quickly through even the smallest openings.
  3. Ammonia (NH₃):
    • Leakage rate: Lower compared to hydrogen and helium, but still relatively high due to its smaller molecular size. Ammonia’s polarity can also affect how it interacts with different membrane materials.
  4. Methane (CH₄):
    • Leakage rate: Moderate. Methane molecules are small but not as small as hydrogen or helium, so their leakage rate is slower through most membranes.
  5. Neon (Ne):
    • Leakage rate: Moderate. As an inert gas with a relatively low molar mass, it will diffuse through membranes faster than heavier gases, but slower than hydrogen and helium.
  6. Acetylene (C₂H₂):
    • Leakage rate: Slower compared to gases like hydrogen and helium due to its larger molecular size.
  7. Ethylene (C₂H₄):
    • Leakage rate: Similar to acetylene, with a slower leakage rate due to its relatively larger molecular size compared to hydrogen or helium.
Summary of Leakage Rates (from highest to lowest):
  1. Hydrogen (H₂)
  2. Helium (He)
  3. Ammonia (NH₃)
  4. Methane (CH₄)
  5. Neon (Ne)
  6. Acetylene (C₂H₂)
  7. Ethylene (C₂H₄)
In general, lighter gases like hydrogen and helium will leak faster through a membrane than heavier gases due to their smaller molecular size and higher diffusion rates. The specific rate of leakage can also vary depending on the membrane material and its permeability to the particular gas.
And about ammonia as a polar gas it adds
Polar membranes: If the membrane material is also polar or hydrophilic (such as certain polymers), it may interact more strongly with ammonia molecules. This could slow the diffusion of ammonia compared to non-polar gases like methane, as ammonia could adhere to the surface or interact with the membrane through dipole-dipole interactions or hydrogen bonding.
Ammonia seems interesting because it could serve a dual use of levitation and energy storage. So a plant producing ammonia would have ample amouts of gas to refill their blimps. I guess Hydrogen is the same though. But their retainment qualities may differ, the small H2 molecules may be harder to seal shut in a thin blimp skin compared to ammonia.
I have to say though that any magnus cylinder filled with lighter than air gas seems quite totally in the science fiction realm to me because I would expect it was even harder to seal a blimp that was rotating in high winds over time, compared eg. to a transport zeppelin.
You have established that levitation is not singularily a factor to choose gas. So it seems my shortlist is:
  • H2 with very explosive and high permeability, large lift, easy to access
  • Ne [edit: I meant Helium here] which is not renewable as of today. High lift and inert
  • Ammonia toxic and less permeable (possibly) and much less explosive than H2
Once I realized, years ago, that Methane (the “natural gas” we all use) is so highly buoyant, it seems surprising it is not used more for that purpose. Take Hot Air ballons, for example: hot air has 87% of the mass of regular air. Not a huge difference. Methane has a density of only 55% of air, a methane ballon would only need to have less than 1/3 of the volume to lift the same weight. That’s a huge difference. And methane is about half as buoyant as helium, so it would seem to be a reasonable choice for weather balloons, as one example. Not only that, but natural gas is relatively cheap and available everywhere. And yet I do not recall EVER hearing about a methane balloon, airship, or blimp, etc. in production for any purpose - even as a toy or research project. Why? Too simple? “global warming” (That would be a new reason, whereas methane has been around forever.) Methane - “The Rodney Dangerfield of buoyant gases”. :slight_smile:
Yes it seems strange to me as well why we havent heard of these. I guess Helium is still to available to need to consider alternatives. And releasing methane/ammonium at high altitude is probably a huge global warming contributor… [sarcasm, please dont reply]
Previously, some gas balloons were inflated with city ​​gas (sometimes turned after into natural gas) which contains a lot of methane.
About global warming or “global warming”, https://en.wikipedia.org/wiki/Permafrost:
Depending on conditions at the time of thaw, decomposition can release either carbon dioxide or methane, and these greenhouse gas emissions act as a climate change feedback[…]
This could mean that if AWE develops sufficiently and industries can capture the methane escaping from permafrost, said methane would not immediately escape into the atmosphere. In this case AWE balloons would be doubly positive.
According to Prices of chemical elements - Wikipedia hydrogen is 1.39 USD/KG, fluorine is 1.84-2.16, helium 24.0, neon 240 USD/KG.
The density of air is about 1.225 kilogram per cubic meter. The density of hydrogen is about 0.08375 kilogram per cubic meter. The difference is 1.14125. To lift a kilogram you’d need 1/1.14124=0.876 cubic meters of hydrogen, which would cost 0.876 * 0.08375 * 1.39 = 0.102 USD
The density of air is, again, about 1.225 kilogram per cubic meter. The density of neon is about 0.8528 kilogram per cubic meter. The difference is 0.3722. To lift a kilogram you’d need 1/0.3722=2.687 cubic meters of neon, which would cost 2.687 * 0.8528 * 240 = 549.9 USD.
So neon would be 549.9/0.102 = 5390 times as expensive as hydrogen.
They can’t.
And using methane is completely insane.
If you want to entertain the idea of lighter than air balloons, hydrogen makes most sense I think, although it is also a greenhouse gas. It is now banned for this use, but you could argue to allow it for unmanned balloons. You could use hydrogen filled ballonets inside the balloon, allowing you to more easily and cheaply integrate the idea. You could also try using higher humidity, perhaps heated, air, as a lifting gas. But then I think you want to insulate the balloon so the water doesn’t condensate so much on the balloon (or ballonet) envelope.
As usual, a lot of math, mostly about using neon as a buoyant lifting gas, which to me is about as insane as it gets - who in their right mind would ever even consider using neon as a lifting gas? Seems quite irrelevant as a point of discussion, to me anyway. I didn’t see anything to back up the claim that using methane is “completely insane”. Why would it be “completely insane”? Methane is routinely burned (“flared”) at the point of extraction, because it is not even worth the cost of containing and distributing it, in many cases.
Sorry I was mixing Neon and Helium there. I meant Helium of course.
I think this also brings up an interesting subject; as some of these buoyant gases are also climate gases (methane 28-36x global warming potential compared to CO2 according to ChatGPT, hydrogen and ammonia small potential). So if Methane was selected as a gas, the leaks worldwide would in sum over time contribute to significant global warming. So a renewable energy world would probably not be built predominantly on methane as an energy carrier.
Ammonia still seems borderline usable though it seems issues with smell, toxidity, corrosiveness and flammability make it a non starter for many applications.
I would like, though to compare flammability of ammonia vs hydrogen. Hydrogen is flammable in concentrations 4% to 75% mixed with air, but the same number for ammonia is 15% to 28%, making it easier to deal with. For example, if a cylinder was filled with “100%” ammonia gas, you would have to mix a significant amount of air and also have an ignition, before the cylinder exploded. Such a leak would probably be detectable through pressure drops if the internal pressure was higher than atmospheric pressure.
So while Helium is both cheaper and better in almost all respects, if it can’t be used, the options seem difficult to implement. And if lighter than air AWE is to give a significant power contribution to the earth, vast amounts would be used.
Lets estimate how much gas is necessary. Lets use the Wind Fischer MAG100 as an example. It is 160 m3 volume and lets assume it produces 100 kW [I did not find any stated power on the web page]. In 2023, 1 terrawatt of wind energy was installed over the world. Lets assume we double that by installing MAG100s. That would require 1.630.000.000 m3 of Helium gas just for the initial fill. This represents (according to ChatGPT) 5% or the world’s Helium gas reserves…
Or we are ignorant of the solutions that are already used. Hydrogen is the best option, if you explore the idea of lighter than air balloons you should look at hydrogen first and make sure that it is difficult to implement, and not just seems to be so. If hydrogen is difficult, any other solution is going to be either more difficult, or plain “impossible”.
So you add a hydrogen sensor. And IIRC you would always have an ignition source so the flame/explosion would occur as soon as possible, limiting the size of the explosion. That is if you are using hydrogen-filled ballonets inside the balloon leaking hydrogen into the balloon.
One idea might be to fill the balloon with nitrogen instead of or in addition to air, but I think then the risk of asphyxiation might exceed the original risk of explosion. Maybe there is a balance.
Using methane is your idea. Do the homework yourself. You can compare the cost of the gas, cost of the larger envelope, impact on other aspects of the design from the lower lift, and so on.
So you could use a magnus cylinder filled with 10% H2 and the rest air and be buoyant enough to be useful and still not too explosive?
Compared to just using off the shelf hydrogen-filled ballonets that doesn’t make sense I think. You’d needlessly use the more expensive impermeable fabric for the whole balloon, and the more expensive manufacturing and design.
Also, Hydrogen mixed with nitrogen may be buyant enough but pose little explosion hazard.
I think H2 can be replenished quite easily?
I’m not a hydrogen airship designer, but maybe you could sense the tension of the ballonet envelope or the gas pressure and include a hydrogen gas cylinder to replenish the hydrogen lost when it gets low. Because of the flammability, permeation, and embrittlement of metals that is going to be more difficult than for helium, I don’t know about other flammable gases.
You could compare the hydrogen lost from the ballonet to that from the balloon, if sensors can measure hydrogen concentrations. Then if the loss from the balloon always exceeds that from the ballonet, hydrogen concentrations shouldn’t be able to build up enough in the balloon to become dangerous.
I think we are probably getting a little closer to what such a system could look like. Add the need that the cylinder must rotate at high speed while still maintaining sensing and replenishing gas, as well as making sure there are no leaks and ignition sources (did you say lightning?). This would be pretty ____ hard to build.
Lightning itself could be a showstopper because it would happen now and then, and if that did lead to an explosion, the noise would be quite disturbing, even if no major harm was caused to third person due to the long length of the tether.
I’m not sure that the ballonets need to rotate, or if they do that the electronics also need to rotate. Or if it is better that they do what the rate of rotation is and what effect that has on the electronics, close to or on the axis of rotation.
Lightning should have a harder time reaching the ballonets I think, or maybe even balloon with lightning rods and landing in thunderstorms. How do zeppelins and blimps manage lightning? Hydrogen concentration should be too low in the balloon and too high in the ballonet for combustion let alone explosion, so the main risk is when the ballonet is ruptured, and then concentrations for combustion are sooner reached than concentrations for explosion.
A post was merged into an existing topic: Questions about Moderation
A post was merged into an existing topic: Slow Chat III
I added a comment of the preprint:
The central heating wire mentioned in the preprint looks to be a suitable solution to keep large balloons in the air even without lift by Magnus effect when there is no wind. Indeed a minimal rise in temperature is necessary, especially if the cover is made of ripstop which is a lightweight fabric used for hot air balloons, kites, sails, para-gliders etc.
The centrifugal force due to the rotation could perhaps have a positive effect if the hotter air comes from the central heating wire, pushing the colder air against the walls, insulating the hotter air in the middle next to the heating wire.
Some calculations for various balloon dimensions. U-value is the “thermal performance” mentioned on https://www.birdair.com/files/brochures/Birdair_ETFE_6pg_WEB.pdf . Formula: "U-Value (W/m² K)". The value of 3 looks to be a realistic U-value. To simplify 0 degrees Celsius corresponding to 273.15 degrees Kelvin, rounded to 273 degrees K.
The table (in French) on https://www.thermexcel.com/french/tables/massair.htm was used for the air mass versus temperature.
The cylindrical balloon of 690,800 m² (200,000 m² for the Magnus effect), 1 km long, 200 m in diameter, 3,1400,000 m³, would require approximately 3.454 MW for an elevation of temperature from 273 K outside to 278 K inside, i.e. a gain of 0.021 kg/ m³, or 659 tons in total, for a mass of 100 tons. With U-value of 3, this would give 10.362 MW, which is still little compared to the average power developed with a wind of 10 m/s (80 MW). With 273 K exterior and 275 K interior we would have 0.009 kg/m³, or 306 tons in total for (690800 x 275) minus (690800 x 273) = 1.3816 MW and 4.1448 MW with U-value of 3, which is very little while we remain well above the mass of 100 tons. With 273 K exterior and 274 K interior we would have 0.004 kg/m³, and 125.6 tons in total, which is fair, and this for (690800 x 274) minus (690800 x 273) = 0.6908 MW, and 2.0724 MW with U-value of 3, which is minimal. If you take into account the centrifugal force, the U-value would perhaps be a little lower. The centrifugal force is higher as the diameter becomes smaller and the angular velocity higher. The larger the balloon, the less power required for its aerostatic lift in relation to the power developed.
Cylindrical balloon 100 m in diameter and 500 m long, 172,700 m² (50,000 m²), mass 25 tons, volume 3925,000 m³, average power 20 MW with wind speed of 10 m/s. (172700 x 278) minus (172700 x 273) = 0.8635 MW and 2.5905 MW with U-value of 3, for a gain of 0.021 kg/m³ (see above), or 82,425 tons. With (172700 x 275) less (172700 x 273) = 0.3454 MW and 1.0362 MW with U-value of 3, for 0.009 kg/m³ therefore 35.325 tons, which is still above the mass, for an expenditure of low energy.
Cylindrical balloon 50 m in diameter and 250 m long, 43175 m² (12500 m²), mass 6.25 tons, volume 490625 m³, average power 5 MW with wind 10 m/s. (43175 x 278) minus (43175 x 273) = 0.215875 MW and 0.647625 MW with U-value of 3, for 0.021 kg/m³, or 10.303125 tons, which is well above the mass, for an expenditure of reasonable energy.
Cylindrical balloon 20 m in diameter by 100 m long, 6908 m², 31400 m³, heating from 273 K to 278 K requiring 34.54 kW, and 103.62 kW with U-value of 3 for a gain of 659 kg. Mass of the balloon (0.1 kg/m² and heating wire) 1000 kg: this is therefore too little. With 50° we would have a gain of 6280 kg, for (6908 x 323) minus (6908 x 273) = 0.3454 MW and 1.0362 MW with U-value of 3. With +27° (300 K) and 0.116 kg/m³, i.e. 3642 kg in total, it would be necessary (6908 x 300) less (6908 x 273) = 0.1865 MW and 0.5595 MW with U-value of 3. With + 10° (283 K) and 0.1247 kg/m³ we would have 0.045 kg/m³, or 1413 kg in total, which is sufficient, and for (6908 x 283) minus (6908 x 273) = 69.08 kW, and 207,240 kW with U-value of 3. This remains a lot but still acceptable compared to the power developed (0.8 MW with a wind of 10 m/s).
A cylindrical balloon 2 m in diameter by 10 m long, 31.4 m³, 69.08 m², mass 10 kg with the heating wire and 0.1 kg/m² of fabric or plastic, would require approximately 345 W (U-value = 1 ) for a gain of 0.021 kg/m³ for heating from 273 K outside to 278 K inside, i.e. 0.659 kg in total. With an increase of 50 degrees from 0 degrees, we would have 0.2 kg/m³, or 6.28 kg in total, it is still insufficient. With an increase of 85° from 0° we would have 0.306 kg/m³, and this is just below the equilibrium point. You would need air at 100 degrees which weighs (dry) 0.946 kg/m³, or a gain of 0.346 kg/m³, or 10.86 kg, which is slightly above. The heating power would then be (69 x 373) minus (69 x 273) = 6900 W (U-value = 1) and 20700 W (U-value = 3). As the centrifugal force would be much greater, we can assume that the U-value would be lower. This is still too much compared to the power developed (8 kW) with a wind of 10 m/s.
The 90 g/m² double-layer aerofabrix ® fabric (https://ultramagic.com/hot-air-balloons/eco-magic/) would be a good insulator, although not very useful due to the very small temperature differences between the outside and the inside (around 2 degrees) for the two largest balloons, and the centrifugal force becomes increasingly important as the dimensions decrease. Silver ripstop would be sufficient, less heavy and less expensive.
Numerous parameters, such like the level of the centrifugal force (angular speed of the cylinder), the temperature gradient (difference between lowest and highest temperatures according to the diameter of the cylinder), could be determined.
Waiting, a heating cable of 2 m long could perhaps be tested inside a balloon which is fixed then in rotation, in order to see the results and calculate if some beneficial insulation could result by knowing aerostatic force.
A company of heating cables:
