Similar topic on hydrogen .
This topic is for discussion and info on how to produce methane on earth, using electricity .
The Sabatier reaction or Sabatier process was discovered by the French chemist Paul Sabatier and Senderens in 1897. It involves the reaction of hydrogen with carbon dioxide at elevated temperatures (optimally 300–400 °C) and pressures in the presence of a nickel catalyst to produce methane and water. Optionally, ruthenium on alumina (aluminium oxide) makes a more efficient catalyst. It is described by the following exothermic reaction.
There is disagreement on whether the CO2 methanation occurs...
Musk plans to build a crewed base on Mars for an extended surface presence, which he hopes will grow into a self-sufficient colony. A successful colonization would ultimately involve many more economic actors—whether individuals, companies, or governments—to facilitate the growth of the human presence on Mars over many decades.
Since the Starships are also reusable, Musk plans on refueling them in low Earth orbit first, and then again on the surface of Mars for their return to Earth. During the ...
“To produce methane on earth” on the vastest scale may be as simple as failing to develop AWE as an effective countermeasure to global warming, so that vast amounts of methane are released from arctic and ocean methane clathrate deposits, and it may already be too late.
Methane clathrate (CH4·5.75H2O) or (4CH4·23H2O), also called methane hydrate, hydromethane, methane ice, fire ice, natural gas hydrate, or gas hydrate, is a solid clathrate compound (more specifically, a clathrate hydrate) in which a large amount of methane is trapped within a crystal structure of water, forming a solid similar to ice. Originally thought to occur only in the outer regions of the Solar System, where temperatures are low and water ice is common, significant deposits of met Methane ...
Windy_Skies
split this topic
December 15, 2019, 7:01pm
#3
2 posts were merged into an existing topic: Climate change denialism
Windy_Skies
split this topic
December 15, 2019, 7:27pm
#4
A post was merged into an existing topic: Questions and complaints about moderation.
