The optimisations continue and they spit out
Rotor radius 2.22m
Blade length 1.4m
TRPT radius 0.5m
TRPT section lengths 1.25m
Elevation angle 18.5
TRPT total length 190m
Tip speed ratio 3.5
This results in an operating altitude of 60m, far beyond the operating height of a HAWT with a power
output of a few kW.
@PierreB
You are now arguing against a 3rd party validation from a PhD on the system with an opinionated throwaway comment.
Please only post relevant data in the thread
Rotor radius 2.22m
Blade length 1.4m
TRPT radius 0.5m
Elevation angle 18.5◦
Tip speed ratio 3.5
Table 5.12: Proposed Daisy Kite System
Design
I don’t see the required lifting kite area in these specifications. The explanation is quite simple: the study of the required lifting kite area is not in the object of the thesis.
With data on table 5.12, the required lifting kite area would be quite huge if even it is possible. See the cause I identified on my previous comments, for example here.
@Rodread I don’t think you seriously believe that a lifting kite like the one you use for a rotor of the same diameter would lift a TRPT of 190 m long with all its mass, drag, plus the rotor thrust (drag)… But, to reassure you, the lifting kite itself could gain altitude, as I suggested in my previous post.
It’s a very long paper and very hard to read - I struggle with it
Still - Amazing what you can miss without looking @PierreB
Ollie disagrees with you on page 221 At present all AWES that utilise TRPT also incorporate a lift kite. The axial force on the TRPT could therefore be increased though improving the aerodynamic characteristics or increasing the lift kites area. It is envisaged that as systems scale up in size the lift kite would no longer be held static. By flying with crosswind motion the lift force produced for a given kite area is increased.
And also it’s just the same static lift kite assumed in the final calculation
check the chapter on optimal system design page 223 to see why Optimised Daisy Kite System Design To design the TRPT the expected axial force and torque that it will experience must be calculated. Using the optimised rotor design, operating at its optimal tip speed ratio of 4.3, and an elevation angle of 25 the rotors thrust and torque coefcients are 0.5 and 0.05 respectively. The thrust and torque coefcients are dependant on the tip speed ratio, their magnitude is proportional to the wind speed squared. The force from the lift kite, for a given elevation angle, is also proportional to the wind speed squared. Therefore, the force ratio applied to the top of the TRPT will be constant for all wind speeds, assuming the tip speed ratio remains unchanged.
TRPT is new and we haven’t needed a transmission with properties like this before.
A driveshaft which was prone to potential torsional collapse was always out of the question because we never tried to get torque from the sky before.
Understanding this was not easy.
But to his enormous credit @Ollie took on and managed to fully describe a phenomenological study in TRPT and a new approach to wind energy harvesting.
This was in stark contrast to the theoretical academic approach to AWES.
I wont accept his achievement being discredited flippantly
@Rodread, the examples you provide have nothing to do with my remark about the required lifting kite area which is not specified in the Table 5.12. I stand by all my analyses, unless you can prove that with the initial 3.2 m² lifting kite, you can lift the 190 m long TRPT to 60 m altitude.
@PierreB If you can not see nor understand how my response directly redressed the error of your sour opinion I can not help you, at least not until such time as you have to witness it in person.
disappointing
The question remains: what is the required lifting kite area for the TRPT of 190 m long?
You can reach an approximation by using the calculator as I have indicated. Don’t forget that the catenary sag effect is most important in the middle between the ground anchor and the lifting kite, at 95 m (95x). In the same time you can evaluate the mass of the TRPT by using the other specifications on the table 5-12: TRPT radius 0.5m, section lengths 1.25m, the tethers. You already have the thrust of the rotor and the drag of the TRPT. I think a huge lifting kite would be needed to reduce the catenary sag effect to acceptable limits, if it is even possible. Hoping that can help.
But that’s fine - It means you actually read and took in some of Ollies info. A good start.
But yes the answer was - the same one - that saggy old cloth single skin faded yellow one
Now you can continue reading and understand that extra rotors in a TRPT bring extra axial thrust … So the tension in the "catenary chain " is tighter.
Now here’s the kicker. Does it matter if a TRPT has sag? No
A TRPT is effectively a Schmidt Coupling chain
Watch this to get the idea https://youtu.be/_iIsibuIs08
So extra required lifting force to overcome extra axial thrust, and to overcome extra weight multiplied by extra catenary sag effect.
No, the first quote is 19 days old. It appeared to me that the torque transfer systems could not scale significantly, and I identified the reasons for this.
I am not interested in these systems anymore, but I think you (and also the readers) should be aware of the limitations. That is the only reason I am asking the question again: what is the required kite area for 190 m long TRPT? Once again you did not answer.
For me this topic that I opened just had its epilogue a few weeks ago. That said, I reserve the possibility to intervene to restore the truth when it is insulted.
@PierreB
Sorry, but You have failed to grasp the concept that kite rotors bring their own lift and then some.
You failed to take account of the real world data I provided several times.
You failed to grasp the concept of an internet forum thread, where the conversation no matter how staggered in time should follow a logical progression.
Here it is once more
A tilted spinning kite rotor has plenty of lift for it’s own mass and some length of TRPT.
You have no evidence nor need to refute that
@Rodread ,I agree to disagree. You deny the catenary sag effect: Does it matter if a TRPT has sag? No. You did not answer to the question of the required lifting kite area for a 190 m long TRPT.
You invoke the real world. The real world = few meters of altitude for any TRPT since numerous years, while any kite (including the lifting kite of a TRPT) easily reaches hundreds of meters of altitude. These are simple and undeniable facts.
There is no denying catenary sag - I have kept you aware of it since 2012
you surely remember, @PierreB , I’ve been sharing videos of catenary effects on kite turbine stacks and AWES configurations with you and the old forum since 2012
Seems I wasted my time .
I answered your question on the size of lift kite required - Same size - You keep ignoring this answer for some bizzare unknown grievance - You have brought no evidence to back up your doubt
I do not understand why the power decreases above a certain TRPT length? Power should increase with increased altitude. What is causing the power to decrease?
There is mass and drag in TRPT
I recommend reading an expert analysis of these systems such as
Modelling and Analysis of Rotary Airborne Wind Energy Systems - a Tensile Rotary Power Transmission Design
The length of the shaft of torque transfer devices including TRPT does not necessarily lead to an increase in altitude, even with a large lifting kite. In the real world TRPT and other torque transfer devices fly at very low altitude, except for the lifting kite. In addition to the horizontal thrust of the rotor(s) (see the video at 1:20 and 2:15), it is due to the catenary sag effect that increases the curvature by multiplying the mass (more in the middle) when the shaft or TRPT length increases (and also the mass by scaling up). As an example the shaft of the torque transfer device (not a TRPT) on the video at 11:15 is very long, but the average altitude remains low, in spite of helium balloons.
See also the right analysis from Dave Santos:Type 1 Lever Principle applies to internal forces of a curved rotating shaft, and the parasitic work required to bend and unbend the rotating catenary curve with each rotation. This drawback increases with shaft or TRPT length, all other things being equal.
@gordon and anyone else suffering through this barrage of misinformation…
I’d treat @PierreB 's reply with a hefty dose of scepticism and care
Yeah, the wind could drop, the backline could hold it down, it could be made of thick steel… List some
With the same video Pierre linked… Try 16 seconds in There’s very little wind and I warn that it’ll likely end in a low wind crash… guess what happened. @pierre is continuing to misrepresent what happened in that field in that video. That was me, filming my hand, holding that line, saying that stuff.
Oddly we can’t see this mystical magical new “catenary” effect in this video even in low wind. An effect as yet to be clearly defined. Maybe it needs it’s own thread.
Following the calculator link Pierre supplies is useless as it refers to straight horizontal catenary sag calculation. Not with one end lifted as is the case here. And even then if you use that calculator with the harsh relevant metrics it shows very little issue.
All AWES suffer from tether drag losses. So too much tether is bad for power return.
Many single line AWES suffer from having to operate so high to perform the giant loops which their control surfaces can not shrink.
The kite turbine study was based on a single lifter, single rotor (optimised version of current one) , variable TRPT
Each configuration will have it’s own maximally efficient height.
In the case of Kite Turbine, line drag is not so bad.
For a start we can choose to operate kite turbines closer to the ground.
Some good reasons for doing that include, It makes the TRPT shorter which is more efficient as there is less drag, The permitting easier, The system safer, You can add more turbines on top if you are looking for more height for less tether, the ground use efficiency is raised, and more.
Reading from section 4.5 Torque Loss in Tensile Rotary Power Transmission - Tether Drag Models of Ollie’s PhD will help
By the end of chapter 4 the prospect of significant torque energy lost in the TRPT (such as in cyclic compression of polygon beam elements) other than line drag has been written off as of little concern.
As I mentioned the rotor descends twice as it is released and rotates, highlighting its thrust during rotation. And the fact that all or almost all the lift is provided by the lifting kite, is confirmed in another video where the rotor flies without rotating.
The question was about above a certain TRPT length, so not directly for a rotor flying at 2 or 3 m height where of course the catenary sag effect is not visible. As I indicated several times (and the calculator includes this) the catenary sag effect increases in proportion to the length. Try with the same rigid rotor but long enough to fly at only 20-30 m altitude (so 10x initial length, so 10x initial sag effect multiplied by mass scaling), not to mention the heights required by AWES intended for harnessing high altitude winds. You will obtain something comparable to what is on the other video with a longer shaft I quoted. Note that straight horizontal catenary sag calculation can apply with one end lifted with comparable effect (with some adaptation), always proportional to the length of the shaft or TRPT.
I am still waiting for the answer to the question: what is the required kite area (in m²) for the 190 m long TRPT flying at 60 m altitude?
