I’d put the subcategories from that into Subsystems/Components, maybe. But the Control category as it is now is better I think. The subcategories definitely should stay. I haven’t posted in there personally because my concept is different, you and @tallakt would be natural contributors there I think.
Interacting between several categories, or between subcategories and categories. As example Subsystems/Components category and its subcategories could also enter Analysis category and Industry and Market Analysis subcategory.
The Analysis category should only include analyses on things outside of the control of the company or product. I don’t think the category is correctly named, but don’t have another suggestion. Weather and who could buy your product is important to any player in the field and you have to adapt to it. I would probably put Laws & Regulations as a subcategory under it, if I was being rigorous, but it is fine as it is now too.
Made some major changes.
Thank you for the feedback! Please look at the changes and tell me if there’s anything’s ambiguous!
As a general rule I’d like to have few categories and encourage the useage of tags to find things again.
Also ordered and fixed the categories in the main menu…
I like it. But the previous categories were fine too I think.
Looking at it, I think the Lounge still is ambiguous. A lounge usually is for off-topic chit-chat. I’d add a subcategory like off-topic or lounge and rename Scrapyard to something not so negative sounding like … Ideas. I would never make a new post in a scrapyard subcategory if it wasn’t about an idea I came up myself.
Now the only engineering analysis subcategory we have is Scrapyard. I don’t think that’s right.
Also, the Lounge category is a special category. IIRC only users with a trust level of 3 and over can see it by default.
Yeah, Lounge was intended as off-topic, but also for things that don’t fit elsewhere.
If there’s an accumulation of topics of one kind that aren’t off-topic, we can always make a new category for them.
Changed default. Everyone can see it.
Scrapyard was intended as a place for failed projects, prototypes, broken things and finding out things that don’t work. Like my own project or Pierres. Ideas can go where they fit. Engineering related ideas into Engineering, etc.
Engineering analysis can happen in Engineering or Engineering - System Design if it applies.
If you don’t put a post into a subcategory, instead putting it into the main category (like Engineering), it kind of gets lost in the noise often. There are so many topics inside the category.
Where would I put a topic about looking at the engineering decisions of Makani or Ampyx?
Topics will get “lost”. A forum isn’t a book or a database. People usually post only on the most recent threads. Threads in the categories are sorted with the most recent on top. I don’t think having more categories would do any good.
If it’s about the system in general, like “have flygen on a plane with a tailplane” etc. then System Design. If it’s more about the plite design itself, then crosswind kites / planes.
It is a database I think. I use it as such anyway. When I want to refresh my memory about a topic I go into the relevant subcategory. Two use cases: (1) discussion, (2) reference. Use case 2 is the reason why I make most (all?) of my new topics.
Added a new subcategory: https://forum.awesystems.info/c/analysis/bizdev
It’s a bit preliminary. The name isn’t perfect. I’d like to have a place to discuss, if companies will make it or not and how their systems will develop. Maybe predictions would be more appropriate, but then that causes confusion with the “industry and market analysis” category.
Hmm… the comparisons wiki is something that requires a bit of a larger database. I don’t believe it isn’t well suited to the format of a forum post. That’s content that could be displayed better on the main site of awesystems.info, but can be fed from the forum. Or on its own Wiki. I made a wiki for testing: awesystems.fandom.com Have a look and see if you think it’ll be useful! The best thing would probably be to host one, but I won’t do that now.
We could try to make a Wiki category with a main Post that links all the Wikis. It’s a workaround, but it might do.
You could imagine it like putting them in the closet in a drawer named “Misc”. - We all have that drawer.^^
I’ll make it easy for myself and say the original posters of the thread can decide.^^
Any suggestions?
I will put mine into a vaguely relevant category, like I’ve done with my Engineering Resources topic. Discourse is unusual in that it even allows not putting posts into a subcategory. I don’t remember that even being an option elsewhere. It shouldn’t be when the category also has subcategories.
Oh I said that wrong. I wanted to ask for suggestions for additional categories. Keep in mind though that there shouldn’t be too many.
Can’t set a posting rule to require a subcategory. But at least one can’t post uncategorized (not sure if one could before).
Now the [WIKI] thing- shall we put the wikis all in one category and make a pseudo-wikipedia inside the forum? Have you considered the alternative of putting things on the main page (things elsewhere can still be mirrored on the main page) or the fandom.com wiki? Should I put this up for voting?
Mine then are Engineering (Miscellaneous) and inside the Lounge: Lounge or General Chat. The names of the things don’t matter so much as what their function is: a catch-all.
You could. That would help with finding them again wouldn’t it? As it is now is fine too I think, but then have them stickied maybe and have a master wiki linking to them all. First impression is that I like this suggestion.
I’ve started a few topics with the intention of maybe eventually turning them into wikis once there has been some discussion and content in the topic. I think I’ve noticed if you immediately turn a topic into a wiki there is less interaction, and someone other than the person starting it is unlikely to edit it.
I don’t want to go to an external site to edit things, that sounds like more trouble than just editing a post here, and needs a deliberate decision to go there.
