I think the focus on % loss is a little misguided. For any AWE, it is quite likely that zero elevation angle is plain impossible.
Conparing with a HAWT (regular windmill) yes you have losses, but you have benefits as well.
Cosine loss only means that you need more wing area to achieve the same power. This is bad, but other factors may be limiting the scale also, like tether strength, power rating of the ground eqipment etc.
And, for a superturbine type og windmill, if you point the rotors horizontally, you need to add an extra force to counter tether downwards pull.
Also remember higher elevation would mean more altitude and higher average windspeeds.
Im not sure cosine losses is the best place to start a design…
Unfortunately the cosine cubed losses are more than the gain from increased wind speed. For example, increasing the tether angle will cause a cosine cubed loss of 46% whereas a 10% increase of wind speed will increase the power by 33%.
Yo-yo mode requires crosswind action. Why not replace the turbines with arrays of kites which are lighter and cheaper. Kites will naturally turn to face the wind during crosswind action providing more power. This is similar to your Orthokitebunch system with a different power takeoff.
Multi-rotor could make the same, enjoying a higher lifetime as the rotors are rigid, and also perhaps easier to implement. Indeed thin rotors are around the tether without transfer issue, only thrust. So the rotors are not connected and are adapted to different wind conditions according to altitudes.
It is true. The same is not easy for rotors excepted for facing rotors like for Makani or FlygenKite.
Yes Pierre, it definitely has the advantage of simplicity, and I’m probably one of the kids who sketched it in the margin of my notebook way back in the '60’s or '70’s. Also underwater versions. By the time I got to college all my margins were full of wind-energy-themed art, mostly just very vague themes.
However my sketch has something still wrong because the Kiwee bevel pulley system has fixed parts on both sides of the rotor, but the axis of SuperTurbine ™ rotates with the propellers. So putting said fixed parts can be a not easy task.
Following up on Pierre’s idea I thought of a modular system where cable drive systems can be linked together while all turbines are oriented to face the wind. Each module will contain a turbine, two pulleys and four idler pulleys. These idler pulleys should not cause much efficiency loss because the contact angle is only about 45 deg. The frame can be aerodynamically designed for minimal air resistance and elements can be canted to provide some lift to the module.
Alternate modules can be made to rotate in opposite directions to neutralize transverse torque. This can be achieved by crossing the cables above and below each module. To prevent the cables from rubbing together we can offset the idler gears and also cant them slightly to align them properly.
This module arrangement looks to be correct. After the weight can perhaps be a difficulty, as well as launching and landing for each module.
In the other hand the pulleys driving the respective rope-drives have a common axis with their respective propellers, unlike the right-angle return pulley used by @Kitewinder. So the motion of the rope-drives is not aligned with wind force among other problems. As a result, the maintenance of the cable on its pulley seems random, as well as the power transmission ratio.
The orientation of the frame is fixed and not random. Visualize a frame where the tether is attached to symmetrical opposite sides. The position of the frame is determined by the tether angle and the location of the attachments. In our case we locate the idler pulleys in the location where the frame is horizontal and the turbine faces the wind.
I think the main pulleys should be oriented like the return pulley of the Kiwee system, in order to assure the efficiency and reliability of the rope-drive.
