High drag coefficient
I haven’t seen a reasoning for doing this that takes into account the supposed lower power available. Let’s say fixed wing flying crosswind has a TSR of 7 and this 0.7, that gives you a 2 orders of magnitude difference in power achievable?
And let’s say the wind speed varies from 1 to 7, what wind speed are you sizing your generator for and can it handle wind speeds outside of that? Can your parachute? Etc. etc.
This topic is about high drag coefficient. Yo-yo mode is described in numerous topics, so it can be easy to know why a high Cd could be interesting, and why I mentioned it, although such an application is not the main object of this topic.
However, the many substantive errors in the previous message lead me to clarify some points already made. First of all it is obvious that what is dealt with here takes place in tether-aligned category as for Guangdong parachute HAWP, not in crosswind category: see the AWES classification which clearly distinguishes these two categories. See also Tethered-aligned vs crosswind kites in yo-yo mode
There is no TSR (tip speed ratio) for tether-aligned AWES, and in this case no “this 0.7”.
In addition, the reel-out speed of the tether depends on the wind speed, not the (crosswind) kite speed, and is conventionally set at 1/3, although it can vary significantly. As a result, the characteristics of the generator will not change fundamentally between using a fast crosswind kite and a tether-aligned device.
Guangdong HAWP describes how their tether-aligned parachute device works: their description is available on Zhonglu High Altitude Wind Power Technology - 中路高空风力发电技术 - #2 by PierreB.
See the section “Parachute Aerodynamics” page 10 and following pages whose the first equation page 14.
The main point to consider is what is called the “tangential force T (along the axe)” (page 10) which is the vector sum of the drag and lift. The coefficient provided on page 11 varies between 0.6 and 1.2.
When I started this topic, I was surprised to see 2.2 Cd, having noticed later that much larger Cd exist: tested Cd of 3.224, perhaps Cd of 5 for some rescue parachutes.
Assuming our Cd of 5 parachute is about 100 m², at 12 m/s wind speed and an air density of 1.2, we would have a power of 76.8 kW (force x reel-out speed of 1/3 wind speed, taking into account the loss caused by the decrease in apparent wind) during reel-out phase.This is not far from half of the average 92 kW tested with a soft wing of equivalent or even larger size and flying crosswind, and by maximizing Power to space use ratio while simplifying steering, not to mention rigid wings which, assuming a positive average power in reeling mode, deviate still more from this important ratio.
Of course, the parachute kite could not fly strictly horizontally (hence the illustrations in my previous post) and would have to have a minimum angle of elevation: at this stage, I don’t know what its Cd would be and also its Cl, hence its tangential force.
But the existence of very high Cd gives food for thought for AWES in yo-yo mode and capable of scaling up to any dimensions, stacking them if necessary.
I use TSR incorrectly to refer to kite:wind speed ratio. I don’t see other mistakes in my short comment. The only positive statement that gives you a 2 orders of magnitude difference in power achievable? is also phrased as a question to invite a reasoned refute.
The question is about accommodating different wind speeds, not reeling speeds. For a wind speed of 7 vs. 1 you would need to have a generator that could handle 50 times the power, and you would need a parachute and tethers 50 times stronger. With something flying crosswind you just need to fly a different pattern.
I would assume there was some mistake before believing an unremarkable shape achieved double the drag coefficient NASA for example was able to achieve. It needs more verification anyway.
On your three points.
1). Indeed, the explanation of point 2) clarifies your previous comment. On the substance, the “2 orders of magnitude difference in achievable power” are based on the surface area of the respective two kites, not their respective masses at equivalent wind power, let alone the power/space use ratio.
2). True, this is an advantage for crosswind kites, although a strong enough parachute could be made in order to work up to high winds, and then partially de-powered by deformation using some of the suspension lines when the winds are too fast. As far as generators are concerned, the problem is perhaps not so different from that of other flying devices.
3). I had even stayed at a drag coefficient of 1 or 1.2. NASA provides (on the following link) a drag coefficient (Cd) of 1.75 for parachute for recovery on Velocity During Recovery . That said a Cd of 3.224 have been tested according to Iris Parachute for an equivalent product.
And you yourself pointed out to me that when the calculation was based on the projected area (which I didn’t initially), the Cd was 5, which I also deducted. You thought it was a mistake, and I had a hard time believing it myself.
I asked the manufacturer for the Cd of their rescue parachutes, without success. I saw that no manufacturer mentions complete specification including both projected area and Cd.
Now, one only has to look at these parachutes to see that they are tiny compared to those of yesteryear. So there has been progress on that: you can now put a parachute in your pocket, which was unthinkable a short time ago. And the information given has little risk of being false for such sharp products: you can’t cheat on the sink rate. As for the shape, if you look closely, you can see a network of straps or ropes integrated into the canopy, which can influence the shape and lead to an increase in the Cd. We already know that bringing back the top of a parachute increases the Cd somewhat (see Increasing Parachute Drag - YouTube).
One thing would be to test a new (or otherwise disused) rescue parachute against the wind and measure the force and wind speed at the same time.
ChatGPT says:
NASA seems to confirm this in the link you also found: Velocity During Recovery and this video calls it canopy area. Another link: fluid dynamics - Reference area of a parachute - Physics Stack Exchange
So, one mistake was to use the projected area instead of the planform/canopy area in the calculation.
The planform area, as described above looks to be the surface area. I used the given surface areas in my first calculations:
TECHNICAL SPECIFICATIONS
SIZE S (19) M (23) L (27)
Surface area (m2) 19 23 27
Weight (kg) 0.87 0.99 1.17
Packed volume (cm3) 2025 2475 3006
Sink rate (m/s) 5.3 5.2 5.1
Maximum load (kg) 85 100 120
Certification EN 12491:2015 EN 12491:2015 EN 12491:2015
Drag coefficients become XXL: 2.65 for S (19), 2.68 for M (23), 2.85 for L (27) if I am right.
You replied:
It is known, and this is even truer for some square parachutes, that the projected area is much smaller than the surface area.
There is a contradiction by writing …as you need the projected area (from the quote just above), then
By dint of contradicting others, one ends up contradicting oneself…
Some use the projected area as reference area, like the calculator above, and others use the surface area, which significantly changes the Cd value.
As an example below:
Apparently NASA uses the “parachute area” (similar to surface area) as the reference area to determine the Cd (1.75), while Fruity Chutes seem to use the projected area in a similar way than the calculator above, which leads to higher values (about 1.6 or 1.7 times more):
https://iopscience.iop.org/article/10.1088/1742-6596/2230/1/012017
PDF:
Influence of angle-of-attack on drag force
AIXIANG Ma, SHIJIN Zhou, QIAN Wu and CHUANLEI Zhu
An interesting article, see Fig.4 page 4 and explanations:
The simulation of the canopies with different angle-of-attack can calculate the drag coefficient directly, which helps to compare the parachute’s performance in the oblique airdrop.
Another relevant publication for the topic:
https://web.wpi.edu/Pubs/E-project/Available/E-project-042407-112440/unrestricted/Brighenti_Duffen_Head_Vented_Parachutes_MQP.pdf
See table 5 page 61, and Figures 34-38 pages 62-64.
The new link (the old link is dead) on tested drag coefficients (Cd) is on Iris Ultra Parachute Cd Performance Log | Fruity Chutes.
I put again this excerpt:
Given that the altitude stays constant, the factors above can cause the Cd to vary by up to 20%. Fruity Chutes rating of 2.2 Cd is considered to be very close to the worst case that we had measured over many flights.
Indeed some measured values are impressive, such like 3.224.
In this thread a Cd of 5 was evoked, but this value is likely very exaggerated, some unknown such like the real (not maximum) load for the sink rate and the ratio between surface area and projected area are not fully known.
The Cd varied between approximately 2.1 and 3.2. As weather conditions and the possible presence of ascendants or descents could modify the Cd values, we could make an average which would give something like a Cd of 2.65.
On the video on a previous comment one can see that Cd is improved when the parachute center is pulled (reefed parachute to increase drag at 0:45).
The following parachute is in a good place for high Cd tested by Fruity Chutes:
We can see that there is a big central hole and this hole is pulled.
It is not impossible that this has the effect of reducing the projected surface, which would initially require more fabric for the same projected surface in order to benefit of a higher Cd, which remains to be verified.
Perhaps I could increase the Cd of this cheap parachute game by pulling the central hole (perhaps it would be better with a larger central hole). Actually I obtained a Cd above 1, but not far more.
Today I experimented the same parachute with a tiny pilot kite.
Parachute of projected area of about 5 m², with a small lifter kite of 0.2 m². This was too small to provide the parachute with a constant and significant angle of elevation. On the other hand, the parachute did not seem to have a tendency to rotate as when it is alone. The tether of the lifter kite was attached to the periphery of the central hole.
Testing a 16ft Annular Parachute
Our Annular design is also the most efficient chute weight vs drag on the market
A simple way to make it fly like a kite? And then a depower device?
Link now:
In this topic almost only drag is mentioned. Lift is also necessary to make an energy kite. Examples of parasails and steerable rescue parachutes are provided, of which the Rogallo being able to become a suitable tether-aligned AWES, some calculations of thrust, drag and lift coefficients (Ct of 3.425, Cd of 2.86, and Cl of 1.9 with an elevation angle of 33°40’, as hypothetical numbers) being here.
A train of these Rogallo kites looks difficult. So I see a single-tether-kite as an unity. I think (only intuitively) that high coefficients would lead to higher waves, so the requirement of more spacing, in addition to spacing by safety requirement. I would prefer few gigantic unities to mitigate these requirements, while being sufficient to fill production gaps in a pumping mode farm.
That said if there is a practical limit of scaling, more numerous smaller unities remain a possibility. Active control with sensors would then allow each kite to move away from its neighbor in the event of excessive proximity.
Depower by a third line or by releasing one of the two lines. Control by a control pod aloft, or in the ground station.
An example of a Rogallo parachute, with specifications (sink rate) perhaps still more promising (with higher coefficients) for a kite use:
Tested as a rescue parachute on:
Why NASA Abandoned the Gemini Rogallo Wing (youtube.com)
The video is almost 40 minutes long. I won’t bother to see if there is anything related to the topic, other than the name “Rogallo”.
Rogallo type rescue parachutes sell well and are available in several brands. It seems interesting to me to try to exploit their high coefficients and their resulting low sink rate. We could make reeling tether-aligned kites with very high traction (Cd of 2-3, Ct of 3-4).
hI pIERRE: wOOPS - CAPSLOK
Hi Pierre!
Here are a couple of tricks to watch youtube videos more efficiently:
  1. if you scroll along the timeline on the bottom of the screen, you’ll see little thumbnails of the graphics at that time. When you see a picture that is interesting, you can watch that segment; When I see an actual glider - I stop and watch. If it’s just some chick talking, I move forward.
  2. Similarly, when scrolling along that same timeline at the bottom of the window, you will notice graphic “hills” along the top of the timeline. These “hills” (like terrain) are highest where the most people go back to watch some interesting part. So the “hills” mark the most interesting parts.
  3. You can click on the “gear” logo at the lower right of the screen, and adjust the speed of the video, up to 2x normal. This alone cuts your viewing time in half.
I was surprised to see 1962 space capsules hanging from what looks like a modern hang-glider.
They kept calling it a “paraglider” back then.
And there was one with inflated fabric “tubes” providing the frame.
Most just had metal tubes for a frame.
I did not notice the simple, pleated triangular parachute version, although i also did not watch the entire video. :slight_smile:
In this video that I finally watched, we constantly see an announcer. It took me 20 minutes to start seeing images surreptitiously.
Indeed, there are Rogallo wings with tubes, others inflatable, and then the fully flexible single-skin Parawing.
Rogallo rescue parachutes use Parawing, improving it with a studied cut and numerous suspension lines. They descend like a parachute while gliding, but with a very low glide ratio (0.6-1.2, instead of 2 or 3 for the old Rogallo hang glider version with tubes). For our AWE use, a glide ratio of 0.66 leads to an elevation angle of 33 degrees, which is the average angle of a crosswind kite. These Rogallo rescue parachutes have a very high drag coefficient (see the low sink rate with a low surface area and a high load), an a good lift coefficient: perhaps they could be kites pulling strong if they are stable enough.
Initially, Rogallo wings, invented by Rogallo, a NASA engineer, were designed for military and/or aerospace purposes.
They then became synonymous with hang gliding, being very dangerous and having caused numerous accidents caused by feathering, some of which resemble those described in the video.
A French site describes Rogallo hang gliders and accidents.
Le parapente est-il un sport dangereux.
Hi Pierre:
Hang gliders have come a long way since the standard Rogallo design of the early1970’s.
I used to dive mine, never knowing until the last few years that I could have killed myself doing that because they can get stuck in a dive, with no way out!
Then a “reflex bridle” was added to the back end of the upper side of the wing, to prevent getting stuck in a dive, and the aspect ratio was increased (wider wingspan) and the chord reduced.
Slowly, gliders got way safer, and performance was increased, over the years.
Today, high-performance hang gliders have a very high glide ratio, high-speed flight, and variable geometry (VG) to change performance while in flight for high-speed flight, or lower-speed flight for takeoffs and landings.
But many pilots prefer the somewhat older style gliders - easier to fly, less demanding of skill, more relaxing in the sky, versus demanding. Like driving a luxury car versus a sports car.
Still, like skydiving, it is a dangerous sport. Anytime you leave the ground, whether for gliding, skydiving, wingsuit flight, base-jumping, mountain climbing, or even general aviation (flying small private airplanes) you are taking a big risk. A lot of the people we met in hang gliding, and pilots I’ve known in general aviation, are, today, dead. Some from other risky activities. Some people take more risks than others.
:slight_smile:
Yes Doug: and now Rogallo wings are used as rescue parachutes for hang glider and paraglider pilots. They descend like a parachute, although they are controlled, having a very low glide ratio, but which would be more than sufficient if they were transformed into tether-aligned AWES, benefiting for their high drag coefficient.
As rescue parachutes are out of service 10 years after sale, whether they were used or not, there must be some somewhere: it would be a good way to recycle them for some AWE research.
